fixing elongated holes in farm equipment??
   / fixing elongated holes in farm equipment?? #1
pharmvet
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Im in the process of refurbishing a JD offset 8' disc. I have taken it apart and plan to have it sandblasted and painted. Im also planning to go back with all new bolts. There are 2 holes where the tongue attaches to the frame, as well as 2 holes in the clevis where the tongue attaches to the drawbar that have been elongated and wallowed out with use. What is the best way to fix this. I was thinking of welding in a bushing of some sort. What can be done. pics would be nice. thanks
   / fixing elongated holes in farm equipment?? #2
I fixed something like this not long ago. I buy the category 2 or 3 adapter bushings that are used to adapt three point hitch sizes to other sizes. I cut, grind or machine the hole to fit so the bushing sits in the hole correctly and then I weld it in. The bushings have always worked for me, particularly for pin through type situations.
   / fixing elongated holes in farm equipment?? #3
Like Mark said or weld them shut and redrill them. I've heard of using a carbon rod of the appropriate size and filling in around it with weld but I've never done that.
Kim
   / fixing elongated holes in farm equipment?? #4
We got into the habit of using the proper dia. pin and would leave it with the implement.It,s wrong size pin that starts the oblong wear.Weld up the egg and redrill to the size of your pin:thumbsup:Dave
   / fixing elongated holes in farm equipment?? #5
To weld it closed and re-drill is good if you can keep your center. If not, Then the Carbon trick is king. I have repaired countless Snowmobile Suspensions made of Aluminum that were elongated because of loose or broken bolts and Plow Brackets of Steel on plow trucks.There is usually an indicator of where the hole is supposed to be. Stick the carbon in there and weld her up. It will not be easy if it is a dead end hole. If it is, Weld it shut and redrill..Using a carbon rod is still as easy as it gets. Or, Drill it to the next size and put in a bigger pin or bolt.
   / fixing elongated holes in farm equipment?? #6
find some copper pipe the size of the pin and use it as a guide to weld around.. seen carbon rods for that too.
that or weld up then drill out true.
soundguy
soundguy
   / fixing elongated holes in farm equipment?? #7
soundguy
soundguy
I've used similar methods. I've used metal pipe and welded it in. Others have mentioned the sleeves to weld in as well. I would try not to use the carbon method unless you don't plan on drilling it out to size. If too much carbon gets into the weld it can become rather hard to drill out, at least for HSS drills.
   / fixing elongated holes in farm equipment?? #8
Most farm repairs like that to get it back on line I put a washer under part one on the under side of the frame after I get it aligned correctly and tighten down then weld washer's fast.
   / fixing elongated holes in farm equipment?? #9
Tom, you reminded me of a way I fixed a hitch on a wagon tongue one time. Used the pipe method for the hole and sized out some washers to fit over it and welded it all together. Worked quite well. Pin was good and snug, just a little tap with the hammer and it went right in. :thumbsup:
   / fixing elongated holes in farm equipment?? #10
I used a piece of thick wall conduit one time to repalce the outter shield on my 8n steering box once.. old one got bent sticking out of the stering box cover.
neat stuff you can do with pipe...
soundguy
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND64FDGH1772 (A57453)
2015 Freightliner...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2007 FREIGHTLINER...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2014 Volkswagen Jetta Sedan (A56859)
2014 Volkswagen...
