kebo
Elite Member
- Joined
- May 16, 2006
- Messages
- 2,931
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
FYI, rail is manufactured in many different weights/classes. The standard way of identifying rail is however much a 3ft section of it weighs will determine it's class/size. Much of North American freight rail is 138lb rail or 151lb rail. That means a 3ft section of it weighs 138lbs, or 151lbs respectively.
If you have some rail and want to know what size it is, see if you can match up the index number stamped into the web with the charts listing most common rail sizes below:
RAIL SPECIFICATIONS
Obviously, the strength of the rail that you sunk 5ft into the ground will vary based on the size. However, rail was not designed for that use, it's designed to bear extremely heavy weight loads in one plane only, and it has to be supported properly before it will do that. I think though if you add a couple guy wires to it, it should serve your purpose just fine. The zipline sounds and looks like a LOT of fun!
RAIL SPECIFICATIONS
