5525 in action - moving hay
/ 5525 in action - moving hay #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I finally got my hay moved out of the field. Two rows of hay there.
I know how you guys like pictures. :)
JD 5525 moving hay
Dodge 3500 pulling the trailer
Red Ox Hay Trailer
D.
/ 5525 in action - moving hay #2
We like pictures of actual tractors doing actual tractor work:)
/ 5525 in action - moving hay #4
D.
Do you use the 4520 to feed with or move big bales in the field?
AKfish
D.
AKfish
Sure, just depends on what equipment is where and how it is configured.
The 4520 had the pallet forks on the front and a trailer move on the back. My Brother was helping me move hay and we needed to load some steel on his trailer when he left. The 5525 was ready to go with a hay spear on the front and rear.
The 4520 actually moves bales very well. In some ways I prefer the 4520. The e-hydro transmission seems to be easier on the machine than hitting the power reverser on the 5525. I moved and loaded 60 bales with the 4520 not long ago.
One thing that is much better on the 5525 are the lights. I rowed up all that hay last night. I got done at 10:50PM or so. The lights on the 4520 aren't good enough to do that at night. I have 2 work lights per corner post on the 5525.
Also - the 4520 moves and feeds bales just fine as long as it is not muddy. It hasn't gotten stuck, but I sure don't want to clean it. R4sw in the stuff we have with an extra couple 1000#s - not good.
D.
/ 5525 in action - moving hay #6
D.
Good to hear, D. Thx. Mud and R4's... and cleaning up! Got a chuckle, there. Just washed the 110 the other day after spreading fertilizer - mud all the way to the hubs.
Couldn't have or wouldn't have been out in the field cleaning up trees and loading them to haul to a burn pit without chains on!
AKfish
AKfish
If I had to do it over - the 4520 would have R1s.
D.
5525 doing fertilizer
D.
/ 5525 in action - moving hay #9
D,
With the vertical exhaust facing out front do you get a lot of fumes blowing towards you?
Thanks,
Rob
D,
Thanks,
Rob
I dunno - I am in the cab with the AC going.
D.
/ 5525 in action - moving hay #11
Right I didn't see the cab in the first set of shots!
/ 5525 in action - moving hay #12
Looks good Darin, enjoyed seeing the pics.:thumbsup:
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
(4) RAM 2000 LB TRAILER JACKS (A64280)
(4) RAM 2000 LB...
Iranch High-End Tricycle (A64119)
Iranch High-End...
1995 CUSHMAN TURF HAULER (A64280)
1995 CUSHMAN TURF...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
John Deere Z994R (A60462)
John Deere Z994R...
