Rotary Cutter Brush Hog Blades
/ Brush Hog Blades #1
Piperflyer
Gold Member
USA
Kubota3030HST
When tuning up brush hog blades is it better to sharpen or leave a little dull?
/ Brush Hog Blades #2
Everything I've read on past posts say you should leave them a bit dull, ie not sharpened to a fine edge. Which reminds me, I've got to get mine in the air to do some grinding soon too. :)
/ Brush Hog Blades #3
Some say yes some say no,for me it depends on what type/how thick.
I razor sharpen blade,it won't take very long to loose the edge after couple good whacks.
/ Brush Hog Blades #4
My Land Pride manual describes grinding a 1/16th-3/32nd bevel, that's all...
/ Brush Hog Blades #5
What are you cutting? If I had a lot of sapplings or blackberries (I do) I would leave them dull. Can't keep them sharp anyway, but the dull impact tends to shatter the stem, making it harder for most plants to regrow (saddly not to blackberries). But if you are doing lots of grass, and also aren't concerned about puncturing tires, then sharper is better.
All of this is IMO BTW. I am not expert on this.
Carl
/ Brush Hog Blades #6
All depends on what you are doing. For rough work, ie, brush, small trees, rough ground, etc. let the blades dull. However, for mowing fields/grasses I keep my blades a little sharper.
New blades aren't sharp at all. Look at the new ones at TSC .
/ Brush Hog Blades #7
Yep, pretty much the same on LP and Woods and I get good results on grass, weeds and brush.
/ Brush Hog Blades
why thanks everone
2018 Kubota RTV 900 4X4 (A62613)
2018 Kubota RTV...
2008 FORD E- 350 S/A MOBILE PET GROOMING VAN (A59914)
2008 FORD E- 350...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
Caterpillar TH255C Forklift (A63689)
Caterpillar TH255C...
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
