Where to buy Nuts / Bolts / Washers ???
   / Where to buy Nuts / Bolts / Washers ??? #1
pharmvet
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Im in the process of disassembling an older 8'JD offset disc. Im planning to sandblast it and repaint it. Im also planning to replace all the bolts, washers and nuts due to rust and corrosion. Where is the best place to order these in bulk? thanks
   / Where to buy Nuts / Bolts / Washers ??? #2
I buy them from Tractor Supply where they're sold by the pound. Buy the hardened version that are corrosion resistant.
Mike
   / Where to buy Nuts / Bolts / Washers ??? #3
I agree...TSC makes it very easy as compared to the big box stores etc...
At TSC as long as all the items (nuts, bolts, washers) are the same grade...toss them in a (provided) bag and they weigh them at the counter and charge you by weight...no messing with keeping all the items separate.
   / Where to buy Nuts / Bolts / Washers ??? #4
buying individual bolts at a hardware store can get painfully expensive, so often "by the pound" alternatives may be better - but not always. they tend to price somewhere between the individual and bulk prices.
if you're a frequent do-it-yourselfer, then it never hurts to have a few extras on hand. i buy grade 5's to keep on hand at mardens (local used/surplus store chain) - probably have 50+ lbs of 1/4-1/2 bolts, locknuts, and washers at all times. when i want grade 8, i find that even smaller bolts can often be $1 and up EACH if bought individually. find a hardware store with a large assortment, and often behind the drawers of individual bolts, they will have full boxes of 100, or 50, or whatever. check prices on these. often a bolt that is $0.75 individually can be bought in a box of 100 for under $20. if you need 10-20 of these, it's a no brainer to get the box. otherwise, try places like fastenal, or whatever you have locally. their prices for full box are very competitive.
   / Where to buy Nuts / Bolts / Washers ??? #5
Here on the east coast, we have some stores called The Nutty Company. They have every nut and bolt you could ever want in quantity or ones and twos. I think they are on line, but the freight is always a stopper for me when ordering small quantities.
   / Where to buy Nuts / Bolts / Washers ??? #6
Depends on quantity required....
For onesie/twosie of something common but weird or special for me (example - 1/4"-20 x 6" long...not every day I need those) I'll just hit TSC to buy just what I need. For anything thats pretty normal I buy all my hardware at Fastenal. Cant beat the prices at Fastenal. Plus when it comes to Metric and the truly weird stuff like Shoulder bolts, they have it all.
   / Where to buy Nuts / Bolts / Washers ??? #7
msc ind supplie sometimes its cheaper to buy a hole box.
   / Where to buy Nuts / Bolts / Washers ??? #8
Put me down as one who agrees with buying nuts, bolts ,washers at Tractor Supply...it is so much easier than Home Depot or Lowes...I mean, they charge you by the pound so you just go pick what you need and it is a done deal at the register on check out..whereas at the big box stores the cashier is trying to look up the sku on every one of the bolts , washers , screws and nuts...and they look at you and ask ...how much was this ? So what is your time worth..?
   / Where to buy Nuts / Bolts / Washers ??? #9
I use alot of fasteners in my business and have found Fastenal to have good quality and a good assortment. I buy almost everything by the box or bag quantity and this lowers the cost dramatically. Anything over 3/4" grade 8 I am more cautious about though since that starts getting pricey.
   / Where to buy Nuts / Bolts / Washers ??? #10
Fastenal is a misnomer. I think I've been there 3 times and not once have they had what I needed.:rolleyes:
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2013 Sakai SV510 Pad Roller, Chassis# VSV21-1033, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2013 Sakai SV510...
ONAN 100DCDB GEN SET (A52708)
ONAN 100DCDB GEN...
2020 Topcat 48" Hydraulic Articulating Skid Steer Cutter, S/N BORC20120101, Asset# 69 (A59076)
2020 Topcat 48"...
2010 Freightliner M2 106 T/A Altec D2050A BR Digger Derrick Truck (A55973)
2010 Freightliner...
2025 AGT H15R Mini-Excavator with Dozer Blade & Pilot Controls  (New/Unused) (A59225)
2025 AGT H15R...
