Front-End Loader Driveway install - FEL, Box Blade or Rear Blade
   / Driveway install - FEL, Box Blade or Rear Blade #11
Thanks for the help so far. If you don't mind I have another question. Have any of the driveways you put in been on hills? If so do you put any kind of drain under the gravel or just crown the driveway so the water runs off to the side?
Thanks
   / Driveway install - FEL, Box Blade or Rear Blade #12
Thanks
is the driveway cut into the hillside, or running up/down the hill? I usually follow the contour.
   / Driveway install - FEL, Box Blade or Rear Blade #13
The section I'm not too sure about will run straight up/down the hill.
   / Driveway install - FEL, Box Blade or Rear Blade #14
Then so will the water. If the hill is steep, stone will errode and wash down the hill. What I usually do is dig in a diagonal swale across the driveway to direct water to the downhill side or cut a switchback driveway in the hillside if it's real steep.
   / Driveway install - FEL, Box Blade or Rear Blade #15
This is an interesting thread because in a couple years I am going to have to move my driveway as the right of way on my property is changing and I will need to connect to the street about 40ft down the road. I figure I will also move the drive to the north side of the house so it doesn't drift so bad in the winter. Are you preparing a bed for concrete, asphalt, or gravel?
   / Driveway install - FEL, Box Blade or Rear Blade #16
Not sure if you mean me or the OP, but I'm just building a stone driveway. heavy base is for heavy equipment and spongy ground. Most guys I know just cut off the sod and lay modified. I did fabric & 4". Next layer will be 3/4" modified.
   / Driveway install - FEL, Box Blade or Rear Blade #17
I'm doing the same as builder, putting down fabric then a 3-4" stone and then modified gravel. Want this to last a long time and since it will be about 1000' long i'm going to stay with gravel for now.
   / Driveway install - FEL, Box Blade or Rear Blade #18
It was a general question thanks for the replies, my current drive looks like someone just put gravel on top of the grass and drove on it. Its pretty bad.
   / Driveway install - FEL, Box Blade or Rear Blade #19
You can try to level it out, put fabric on top and then another 4" of modified.....or just add more modified until it gets solid.
   / Driveway install - FEL, Box Blade or Rear Blade #20
Stupid question....What is the purpose of the fabric that is soo often talked about here.??
I asume it is to keep the weeds from sprouting up.??
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Galvanized steel Fence (A53424)
Galvanized steel...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F750 XLT...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
Ford 8340 (A53317)
Ford 8340 (A53317)
