My "new" 6x4 Gator is finally here.
   / My "new" 6x4 Gator is finally here. #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I picked up a used 6x4 Gator. It needs some work, but oh well. I have ordered the manuals on it. It will come in handy.
D.
   / My "new" 6x4 Gator is finally here. #2
I bought a new 6x4 diesel in '01. Good machine, rough ride. Dealer installed a shock absorber to the accellerator pedal which helped dampen the movement over rough ground. It would climb nearly any hill I wanted to go up, just had to get used to the fact that the front end would come off the ground when you topped the hill. It wasn't really good in the mud, not much ground clearance and would bottom out quickly. The '04 HPX diesel I traded it for has been a real improvement over the 6x4, better ride and handles mud much better.
Yeah - they do ride rough and it feels like a low rider. I see they used to offer chain guards (skid plates). I think I will be fabricating my own - looks like JD does not offer them any longer.
I bought this thing right, but it is going to take $500 - $1000 in parts to make it right.
I used to own a HPX - I can see why they quit making these.
I am looking to put it out at the hunting camp for hauling feed, etc.
D.
   / My "new" 6x4 Gator is finally here. #4
It was a good, heavy duty machine. The diesel engine had a bad rompiing surge in it at idle that the dealer couldn't fix. Finally replaced the engine although it probably was the injector pump. The brakes didn't stop very well and made a lot of noise. Added a bottle of John Deere Friction modifier to the trans fluid and it cured the braking problem.
My HPX has been almost trouble-free. I hope I can trade for a new model this fall.
   / My "new" 6x4 Gator is finally here. #5
That is a "beefy" looking frame on that roll cage!
I am not even sure how the brakes work on the 6x4. They sure are loud. I was looking oin the Jdparts site and they showed a clutch pack. Do I have to tear the transmission apart for that?
I planned on changing all the fluids anyway. I assume the friction modifier is not standard?
D.
   / My "new" 6x4 Gator is finally here. #8
The brakes are inside the trans. When you change the fluid, add a pint of John Deere Friction Modifier to the trans. It made all the difference to the brakes on my 6x4. Your brakes may be worn out but it's worth a try.
I will try the friction modified first.
Have you ever torn down the brakes? I ordered the tech manual. I hope the friction modifier does the trick.
Was it in a separate jug?
Did you have chain guards on yours?
D.
   / My "new" 6x4 Gator is finally here. #10
Never tore into the brakes. The JD friction modifier was in a small pint bottle at the parts dept. Just add it to the trans fluid. Did not have chain guards.
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A55973)
2019 Allmand...
2005 Jeep Wrangler 4X4 SUV (A56859)
2005 Jeep Wrangler...
JMR MINI GRAPPLE (A56857)
JMR MINI GRAPPLE...
Toyota 7FDKU40 7,350lb Forklift (A55973)
Toyota 7FDKU40...
