Home made Box Scraper
/ Home made Box Scraper #1
Inky05
Kubota BX24, Kubota L260
Built this one myself.
/ Home made Box Scraper #2
Very nice little unit. May I ask why you chose to build yourself and what your total build cost were?
Chris
/ Home made Box Scraper #4
Looks right off showroom floor..nice work. :)
/ Home made Box Scraper #5
Nicely Done!!! What did it cost you?
Jim
/ Home made Box Scraper #6
Great job! Have you given it a test run yet?
/ Home made Box Scraper #7
Looks GREAT! Those rippers/scarifiers look like they can go lower than manufactured units. I'm certain that you will find a box blade to be very, very useful.
As for the cost... I got most of the materials for free... so I couldn't tell you what it actually would cost...
Before I painted it, I used it to re-grade the driveway and to take the sod off for the new garden. On the garden job, the rippers wer six inches down and it worked great. They held up well. The actual blades and the little triangular piece at the bottom of the rippers is made from AR plate. They will tend to "work harden" with use.
/ Home made Box Scraper #9
Nice work. I can't see the bottom of the 4 in box tubing, but I would recommend you beef up the area behind the ripper, on the bottom, so when you grab a big rock, the ripper does not rip out some of the 4 in box steel. You have enough shank there that it could happen.
I considered doing just that from the beginning. The 4" box tubing is 1/4 wall and the slots are milled in so they are radiused on the ends. This helps to prevent tear out. So far the ripper shanks just indented a little where they hit against the radius.
If tear out becomes an issue, I'll reinforce it with a piece of 3/4 x 1 across the back of the rippers below the box tubing.
(The better commercial ones are 1/4" wall)
/ Home made Box Scraper #11
Looks good - like all those extra height selections on rippers - most rippers do have the replaceable tips that slide up onto the shank instead of the pressure going right against the weld, you've obviously got the skills to make whatever is needed should there be any problems tho - wish I could do that - good job! when will you be marketing these? I want one!
/ Home made Box Scraper #12
That's a great looking boxblade. Nice job!
/ Home made Box Scraper #13
My store bought never looked that good, think I will go outside and move it a bit further under the trees or maybe in that clump of honey suckle.
/ Home made Box Scraper #14
I just bought one for $775 and can't wait to get it up to camp and try it out saturday. Would have been nice if you had a video of grading the driveway. Guess I will have to shoot something for U-tube this weekend.
/ Home made Box Scraper #15
It would appear you got a trailer full of box blade.:thumbsup:
2011 BEAST 48 ELECTRIC RTV (A64280)
2011 BEAST 48...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
2011 Bobcat E50M Mini Excavator (A61572)
2011 Bobcat E50M...
PALLET OF MISC PARTS (A63291)
PALLET OF MISC...
