MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,146
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I've always wanted water out at my garden, rather than running a garden hose all summer. So I used my $10.00 soil slicer/trencher thingy today and pulled in about 150' of black plastic pipe from the house to the garden. First, I ran the blade from the garden to the house. I was able to do it in one pass at full depth, as we have pretty sandy soil, and it rained a lot over the past few days.
Next, I dug a 12" hole at the garden end about a foot and a half deep. I then laid out the plastic pipe behind the PT and under it. I folded the pipe over about 6" and tied a stout rope to it and taped it flat. Then I tied the rope through the bottom hole of the blade and lowered the blade into the hole. Then it was off you go. I just re-traced my pre-sliced trench. That is the beauty of things in the front!
Surprisingly, it slipped that pipe right along and I was done in about 2 minutes. :thumbsup:Unbelievably easy.
The run was mostly straight, except I had to make a left and a right around a tree. I felt the rope snap right at the end. I should have used a chain or steel cable. I figured there was tons of pressure on it. My neighbor was watching and came over. He saw the broken rope and thought it was a lot of pull too. However, I found the end in the dirt, pulled it up with my hand and even with the pipe a foot under ground and an S curve in the middle I was able to pull the pipe back and forth through the entire trench with just two fingers. I really cannot say why the rope broke at all. A child could have pulled it. Perhaps it caught a tree root or something.
Anyhow, all that blade is is a plow share I found at TSC about 8 years ago for $10.00. It works great and I highly recommend it if anyone wants to pull water lines around their yard. It left very little damage that will probably be unnoticeable in just a few weeks. :thumbsup:
I have also used that blade to edge my overgrown driveway and to put edges on softball diamonds when refurbishing them.
