Any pic's of the backhoe sub frame for a LK30
   / Any pic's of the backhoe sub frame for a LK30 #1
iwanta
Member
Tasmania Australia
2009 Kioti LK30
Wondering if anyone has taken pic's of the sub frame, there's no dealer close with a kioti backhoe and sub frame to look and curious as to how the sub frame is attached to the tractor and hoe, how easy it is to get on and off and any other information about the sub frame connection :thumbsup:
   / Any pic's of the backhoe sub frame for a LK30 #2
The hoe is very easy to remove; it is attached to the mount via a four point arrangement. To remove; lower stabilizers and boom to the ground to support the hoe. Pull-to-release handle is below seating area of the hoe; this releases the locking "dogs" from the tractor mount. Utilizing the tractors' hydraulics, raise the hoe until it disengages the bottom hooks of the mount and slowly drive ahead from hoe a couple inches(not familiar with the metric equivilant).Place support blocking under hoe and lower hoe onto said supports. Disconnect the two hydraulic lines to the hoe and drive off. The mount (sub frame) stays with the tractor and would be burdensome to remove as it's bolted in many places to tractor requiring the removal of the rear tires and a couple dozen bolts. I have no pics available, sorry
Thanks Patches, obviously the sub frame is tucked in close to the tractor's rear so as not to inter-fear with the 3 point linkage when the hoe isn't on the tractor. Still like to see some pic's if anyone can oblige ;)
   / Any pic's of the backhoe sub frame for a LK30 #4
I have a case with a backhoe, sounds like the installation and removal are about the same, If you want some pics of my setup i will post:thumbsup:
   / Any pic's of the backhoe sub frame for a LK30 #5
Here is a picture from the manual, the subframe bolts to the side of the tractor rear housing, the long bar ties into the loader frame.
I think this is one of the best designs, easy to get hoe on and off and easy to use three point.
Joel
   / Any pic's of the backhoe sub frame for a LK30 #6
Is there only one of those long beams that tie into the FEL subframe?
I have seen the LK3054 and its dedicated 2376 hoe. I like the way it
attaches and it seems substantial. I hope the newer LK30 does it this
way or better.
   / Any pic's of the backhoe sub frame for a LK30 #7
way or better.
There is a beam on either side, locking/bolting into the loader frame with ,I think, (16) 14mm bolts, and 9 bolts(8 of which are 14mm and one 12mm) to the tractor frame/engine in several places; a very substantial mount. To the best of my knowledge, the LK30 is identicle
   / Any pic's of the backhoe sub frame for a LK30 #8
What patches said
the hoe frame bolts to the loader and to the tractor's cases including the rear end housing
really nice set up and I really like how the Joe is high and tight to the tractor
Joel
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
2017 DODGE RAM 2500 (A58214)
2017 DODGE RAM...
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
