Tires Bridgestone Farm service lug-w size 8-16
   / Bridgestone Farm service lug-w size 8-16 #1
ouachita
Arkansas
iseki TS1610
I was wondering if some one could Ansewer a question mark (?), on a tire Issue. i have a iseki 2/WD-Tractor TS1610 the rear tires are bridgestone farm service lug special.. size 8.3/8-22 MY question is can you run a smaller tire like a Bridgestone Farm service lug-w size 8-16 on this tractor..
Any help would be appreciate.
   / Bridgestone Farm service lug-w size 8-16 #2
As long as the rolling circumference isn't excessively smaller or larger.. I see no reason not to use them as a pair... 2wd tractors have no issue with tire matching.
The tires just need to be within a few inches height of the originals.. they need to fit in the fender and they need to keep the tractor fairly level. The rims need to fit the lugs...
   / Bridgestone Farm service lug-w size 8-16 #3
I have 8-16's on my Ford 1210. They are about 31 inches in diameter when new. The old ones I took off were maybe 30 inches in diameter. I restored my tractor so I bought new ones.
   / Bridgestone Farm service lug-w size 8-16 #4
The Bridgestone 8.3/8-22 is 37.5" diameter. The 8-16 tire is 30.5"
The tractor will sit 3 1/2" lower in the back.. can the tractor take that difference?
8.3-22 (FSL S) 4 7.00 8.2 37.5 2.16 17.6 45 1170 @ 22
Farm Service Lug
TITAN HI-TRACTION LUG R-1
Catalog #: 48D667 Ply Rating/Load Index: 6
Size: 8-16 Rolling Circumference: 91
Size (English Equiv.): -- Overall Diameter: 30.5
TT/TL: tubeless Gross Flat Plate, in2: --
Brand: Titan Tire Loaded Radius: 13.9
Inflation Pressure: 28 Rim Width: 6
Max Load MPH: 20 Tire Width: 8
Max Load pounds: 1360 Tread Depth 32nds inches: 31
Special Order: no Weight: 38
Titanョ Tire catalog
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
1761 (A58375)
1761 (A58375)
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
2001 KENWORTH T800 BOBTAIL KILL TRUCK (A58214)
2001 KENWORTH T800...
2021 International MV607 Dump Truck (A56858)
2021 International...
1990 MACK RD688S (A58214)
1990 MACK RD688S...
