Thoughts on planting maple seeds in alfalfa
/ Thoughts on planting maple seeds in alfalfa #1
nmu98
JD 5203, JD 3720, JD 4110, JD 445, IH 1586, IH 886, IH 404......
I have been working on planting my 5 acre alfalfa field into trees. Currently I till up a large are and plant the trees in rows so I can keep tilling close to them to keep the alfalfa and weeds down. It takes a lot of time that I could use in other ares of the field. The rest of the 20 acres is currently trees that I have planted over the last 5 years.
So, I was thinking, I could pick up a ton of the maple seeds that are dropping now and spread them through the alfalfa. That would allow me to get a more forest like look since they would not be in rows and it would keep the weeds down around them and force them to grow tall instead of outward. But my fear is that the alfalfa will choke them out.
Ideas? Suggestions?
/ Thoughts on planting maple seeds in alfalfa #2
Try it. Nothing lost.:D
You could also transplant small seedlings and see what happens.:thumbsup:
Throw in a few other Hardwoods?? :D
Some Bird friendly trees?
A few shrubs?
/ Thoughts on planting maple seeds in alfalfa #3
Red Maple (soft maple) grow pretty well in open fields. They love sun and wet. Sugar Maple (hard) is shade tolerant and prefer low light levels when they are sprouting.
A few shrubs?
I have 15 other acres of various trees. What I have learned from planting this farm field into a woods is that it is easier to start with a fast growwing tree like a poplar or silver maple and then plant the more expensive hardwoods later once the other trees have the weeds tamed back a bit. since the maples are free, I thought I would try it. The cost to me is what I would make on selling the hay. So I really do not want trial and error, if possible.
I have some sugar maples mixed in on the edge of the alfalfa and they are not thrilled about it. They are growing at a 1/3 of the rate the others are. Thats what scares me about putting trees in the middle of the alfalfa. There is not much water......... But also not much wind either...... I think I am planting silver maple, or slight variations of it.
/ Thoughts on planting maple seeds in alfalfa #5
I think the alfalfa will probably choke them out. A forester told me that I should disc or shallow plow around the forest edge on my place to let the seed trees natually re-populate old fields. The grass tends to choke them out. Happens in a grazed woodlot once grass grows --- new trees take quite a while to establish unless the grass is taken off.
If you plant the maple seeds in dirt they will grow -JMHO
/ Thoughts on planting maple seeds in alfalfa #6
I fall disk and then brodcast red, white, and burr oak acorns, black walnuts, shagbark, shellbark, bitternut and pignut hickory nuts, and hard maple seeds. I disk the seeded area lightly and then run a culitpacker over it. Squirrels and birds 'plant' many other varieties that are bird and game friendly. I let the weeds take over which slows the growth for a few years but it is low maintenance. I did try to frost seed (broadcast in Feb) red clover over the last tree seeded area this past winter, but it is mostly weeds so far. Time will tell on that area. A better plan would be to kill the weeds well in advance of tree seed planting, but I didn't do that. If you have alfalfa, you could just disk that and plant the tree seeds, and then plant clover if you'd like. I used to plant hundreds of seedlings yearly but the broadcasting of seed gets MUCH better results with less work. I pick up the seeds by the bucket full at state or metro park areas. Anything from the white oak family germinates shortly after dropping from the tree so you have to collect them right away.
/ Thoughts on planting maple seeds in alfalfa #7
Why not spray round-up or something similar to kill off the alfalfa first?
/ Thoughts on planting maple seeds in alfalfa #8
For what it's worth, we reforested a 4 acre field 20 years ago. Our goal is veneer timber for our ancestors. :laughing: Anyhow, if you want tall, straight trees, you have to stress them when they are young to get them to reach for the sunlight. We planted alternating rows of pines and mixed hardwoods. The pines grow fast and are wide at the bottom and skinny at the top, just the opposite of a hardwood tree. The pine rows force the hardwoods to grow tall and straight between the rows to reach for the sun. I can honestly say the the pines are pushing 40' and the hardwoods are tall, straight poles with their branches poking out above the pines.
When we planted the trees, we got into a government program that helped pay for part of the planting. Since our soil is highly erodible, the state wants to stabilize the soil. They ended up paying for 75% of the cost. So we got 2150 trees bought, planted and side sprayed for under $300.00... all done in one day. I suggest you look into programs like this in your state.
The only stipulation was that for the first 5 years we MUST side spray the trees once a year to keep weeds down OR we MUST mow between the rows to keep the weeds down as needed. The state forester stressed that weeds and tall grass is the enemy of the trees and the program would be void if we did not control the weeds. So after the first year, we mowed between the rows. After 6 years I could hardly get the tractor down there anymore anyway because the pines bushed out as planned.
I really didn't think the hardwoods were doing all that well for the first 10-12 years, as they were skinny and spindly. Well, then they started adding height and popped over the pines about 4-5 years ago. Now they are adding girth! :thumbsup: Most of the pines are around 12" diameter at 3' up from the ground. Most of the hardwoods are 8-10" at 3' now. They were only 3-4" just 4-5 years ago.
If I were you and wanted to start my own seedlings, I would:
1. Start them in a nursery bed where you can control the weeds for the first 2-3 years.
2. Don't transplant them out to the field until they are 3' high.
3. Make sure you have a plan to control weeds for the first 5 years.
4. DO NOT plant only 1 or 2 types of trees. If a disease or pest comes through, it will wipe your entire forest. Plant MIXED HARDWOODS (we've got 7 different Oaks, poplar, maple, walnut, cherry and a few other species).
5. Consider planting a windbreak around the field with a double row of pines then shorter trees like crab apples, then shrubs on the outside that bear fruit and berries. The bunnies and deer like fruit and berries more than they like tree saplings. They will eat those instead of your trees. ;)
We lost MAYBE 10 trees total out of that first 2150. We were very lucky. The place is full of deer, turkeys, bunnies, etc... I was just out there this weekend and it is now a forest. We may start cutting pines out in the next few years as they have done their job well. :thumbsup:
/ Thoughts on planting maple seeds in alfalfa #9
nmu,
I'm basically doing the same thing as you converting alfalfa to trees and tilling, planting and mowing, mowing, mowing every year.
Wisconsin DNR says that if you're not gonna bother with weed control then don't even bother planting. Probably goes double for alfalfa as that chokes out most everything.
You can certainly try broadcasting seed and hoping for the best, but with your experience tilling, mowing and converting other parts of the field to trees I bet you know how broadcast seeding is gonna turn out.
Best of luck,
I hate to have all my trees in rows, but I think trying to take the easy way out is going to result in poor production. I guess its time to til up more alfalfa and plant some trees.
Thanks for the input guys.
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
Zero Turn Mower (A59231)
Zero Turn Mower...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
