Buying Advice JD Serial Number
/ JD Serial Number #1
bunyok
Im looking into purchasing a JD 755 or 855 tractor.
The serial number tag is missing from PTO casing. Does anyone know where else to look for the serial number? Would definitely like to know which model tractor is.
/ JD Serial Number #2
Are you just wanting to know if it is 755 or 855, or maybe which version of each, or the actual serial number?
/ JD Serial Number
Anything that can tell me what model it is.
thanks
/ JD Serial Number #4
Quick at a distance difference between 755 and 855 is length aft of engine side panels. On 755 the engine side panel ends just below the letter R in DEERE. On 855 (and 955) the panel ends below the letter D. I assume the tractor you are looking at does not have those side logos, but this picture should give you an idea of that difference. That length on the 755 is about 5 inches.
/ JD Serial Number
my problem is the tractor is missing the body components, it's a deal I don't want to pass up even if I take it for a parts machine, but I would like to get it up and running.
/ JD Serial Number #6
Can you measure the wheelbase? Distance between center of front and rear wheels. 755 is 57 inches. 855 is 64 inches.
/ JD Serial Number
that will help, I'll pay a visit to the seller and measure up.
thanks
/ JD Serial Number #8
Also that square tube loader bar mount in the 755 frame is only about 2 inches in front of the foot rests. The 855 would be about 8 inches in front of the foot rests.
/ JD Serial Number
from the wheel base looks like a 755
do you have any idea where the serial number might be besides pto area.
this tractor is a bit rough around the edges and dosen't run at the time. cranks but won't start but I will worry about that later.
one further thing is there a way to unlock the rear differential manually?
thanks
/ JD Serial Number #10
If its such a deal you can't pass up buy a repair manual for it after you winch it on a trailer. Sounds like you would get your moneys worth out of the enclosed information. Don't be surprised if you can't buy hardware store parts for the deere. If you need Yanmar parts better sit down. A prior estimate probably discouraged the prior owner.
After you spend two weeks ordering parts and repairing you will find a cherry example for 500 more. That is the way it usually works.
** What did they do with the sheet metal.... feed it to the goats ?
/ JD Serial Number
I just wanted to be sure what model it is before I give Me. Green to the Green.
Still would like to be able to have it free wheel rather than dragging it in gear.
/ JD Serial Number #12
thanks
There is a number on the right front side of the frame but I don't remember if it is the serial number because it is covered by my loader mount bracket.
Did you move the two-speed gear selector to the center Neutral position?
/ JD Serial Number
if the selector is where it should be everything is in neutral position. had tro drop the driveshaft to free roll the front wheels. will play with it further.
thanks
/ JD Serial Number #14
thanks
Then the MFWD (four wheel drive) is still engaged. The diff lock should not stay engaged unless it's stuck-and it only effects the rear.
/ JD Serial Number #15
The MFWD lever is just to the left of the seat. Pull it back all the way to disengage.
/ JD Serial Number #16
Hmm....No sheetmetal, no serial number....the skeptical side of me initially says "was this machine stolen and stripped to hide its identity?"
Obviously if you know the history, this is not the case.... My thing is...With the placement of Serial Number tags these days, theres really no way they just fall off accidently.
Another thing to think about...especially with that machine because they made them for so long...there were so many serial number breaks etc, that you could be in for alot of heartburn at the parts counter if you dont have the SN#
/ JD Serial Number #17
Well I became curious enough about my memory and removed that loader mount bracket to check under it. The factory serial number is in fact heavily engraved on the frame. It is on the outside on the right side very near the front of the tractor. I assume your tractor does not have loader mounts on it, but in case it does just remove the three large bolts on the wing mounted in that location. I can see no reason that s/n should not always be there unless it has been very purposely gouged out. That would be tough.
/ JD Serial Number
thanks, if it is gouged out I will be staying away from it. I don't need any visitors.
/ JD Serial Number
the hood and front cowling is there with brackets but no side panels.
my thoughts are the same as yours if numbers have been purposely removed.
thank you
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
2016 Autocar ACX Xpeditor T/A New Way 31ASL 31Yd. Side Loader Garbage Truck (A66736)
2016 Autocar ACX...
213085 (A64276)
213085 (A64276)
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
340 GAL WATER TANK (A68842)
340 GAL WATER TANK...
