JD 5525 in the field (wet one).
   / JD 5525 in the field (wet one). #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
TBN people can never get enough pics. It was a really wet winter. Was out putting hay out and snapped these pics on my way back to the barn. No, I didn't get stuck. Love that tractor,
D.
   / JD 5525 in the field (wet one). #2
Looks like it's going to be wet for a while too. P.S. Nice tractor !
   / JD 5525 in the field (wet one). #3
Ok, no one is on the tractor. Who got out and back in after taking the picture?:D
Those size of tractors are great in the mud. Have enough clearance, big enough tires for traction, and not too heavy.
I took the picture. Somebody had to open the gate!
D.
The more I own the tractor the more I like it. I am not sure something bigger would add any value. A 5105M for our operations would be the perfect tractor I think.
Better than the 5525? A tad more power and the coolers are way easier to clean. When haying in the summer - cleaning those cooler is a must and it is a PITA.
D.
   / JD 5525 in the field (wet one). #6
D.
Spring is SOOOO much fun...!!! Overshoe sucking days!
I can remember times when I'd have to walk to the back of the tractor to cut and pull the twine off a big round bale before I'd unroll it for the cows.. be at least 2-3 times a Spring when I'd pull off one or both overshoes and maybe end up with one knee in the muck, too!! :mad:
I teeter back and forth between a cabbed 4720 and say; a cabbed 5075M. Don't know enough about the transmission options for the M series and the various pros and cons of each variation.
What do have in your current 5525? What would you do differently with a new 5105M?
Thanks,
AKfish
Thanks,
AKfish
I have the 12/12 Power Reverser It is very rare I need another gear for the work I am doing. The upgraded trans in the M is pretty expensive.
I have a 4520 cab also with R4s. The 5525 has R1s. The 4520 stays in the barn in that kind of weather unless the 5525 is broken or we need two tractors.
D.
   / JD 5525 in the field (wet one). #8
Thanks, D. R4's are... well, they're R4's aint' they!?! I've still got my rear chains on my tractor - likely leave it that way until June.
I'd be stuck ALL the time if I didn't!
Wonder if you'd still be OK with the 12x12 runnin' a small square baler - say, a JD348?
AKfish
AKfish
I hear ya.
People have been baling for years with less gears - I suspect it would be fine. I don't think I would want anything less than 12/12. I look at the 6D series and I really think the transmission is holding that tractor back.
Are you baling with a 348 now?
D.
   / JD 5525 in the field (wet one). #10
No 348. Hoping the 336 is gonna do the job. Don't stop at the 6D -- go for the Premium with an IVT!!!
I like to test drive one of those... the IVT or CVT or whatever those tranny's are - appear to be very simple but durable.
AKfish
2013 MACK PINNACLE (A50854)
2013 MACK PINNACLE...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
