Pics from Power Beyond Installation
/ Pics from Power Beyond Installation #1
Nuru
Elite Member
Got my PB installed this weekend. Here are some pics. Took a while, as I was doing other cores during the installation. Also my crowfoot wrenches are still in transit, due to arrive tomorrow, so I had to do it with regular length wrenches - that was too much fun:(. I also had to remove both rear tires. If I had the crowfoots, I would have had to only remove the right rear. I forgot to take a pic of the tractor up on the Powerbuilt 3 ton jack stand/bottle jack combos as my kids came out and were asking me questions about the job and other stuff. Those Powerbuilt combo units worked out real well. Jack up the tractor and lock the safety latch and away you go. No need to use floor jack and separate jack stands for the job. The last pic provides the best shot of the final install. Only thing I did not move the MMM hoses connected to the 3 SCV out of the way for the pic. I will do that tomorrow and then upload that pic. Same thing on the "tall" pic.
/ Pics from Power Beyond Installation #2
Nice work on installing the PB kit. I just wish Deere would make the connector sit higher up and away from the top-link. If you put a hydraulic top-link on, you may or may not have the cylinder rub the quick-connects loosening them just enough cut off hydraulic fluid flow. I've had that happen. It would be nice if they gave an extra inch clearance between the connectors as trying to push the retainer ring back with gloves on is a PITA in those tight quarters.
Picasa Web Albums - Matt - Hydraulics Up...#
Picasa Web Albums - Matt - Top-n-Tilt#
Is that an extension on your hydraulic oil fill tube? I'm going to have to see if it shows up on JD Parts. I sure would like one on mine as the hydraulic kits make getting to the filler cap a PITA.
/ Pics from Power Beyond Installation #3
Good job, Nuru! Thanks for sharin'. Are you in the planning stage for a backhoe, now?
Any plans for a diverter and more SCV's?
AKfish
/ Pics from Power Beyond Installation #4
Nice:thumbsup: Thanks for the pictures;)
/ Pics from Power Beyond Installation #5
I agree. The top drawbar runs right through the pb on my 955. There should be a better way. Nice pics. They are sure to help others.
/ Pics from Power Beyond Installation #6
One Q...
Whats the story with the nee Toplink "Storage" Bracket? Is it a necessary install? I agree with mjncad, I removed my standard bracket as soon as I got my HTL because of clearance issues, and I'm thinking this one would be even worse then the original...
/ Pics from Power Beyond Installation #7
Thanks for the pics.
I removed the top link bracket when I added the HTL. Just in the way.
Thanks, Yep that is an extension tube.
AKfish
Thanks Akfish!
Nope, just the PB and the log splitter at this tiime.
One Q...
Actually, yes it is required. The new bracket is where the frame for mounting the new hoses, pipes and connectors, is mounted on the tractor. I will get a pic to show that soon and posr.
Oh, yeah, good point on the Hydraulic top link clearance,
Thanks 955er!
/ Pics from Power Beyond Installation #14
I found the extension tube on JD parts after seeing your pictures. It's about $42 for the tube, and another $20 - $25 for the adapter fitting.
I'm putting it on my wish list after I get further along with a modification I'm working on back there.
Great I am glad you were able to find it.
Yeah, separately it is a bit expensive, in the kit its buried, in the cost. So i guess the rest of the parts are $250+
/ Pics from Power Beyond Installation #18
Everything is pricier separately; but ~$60 is not a deal breaker, just more than the parts are probably worth.
Oh yes they will go for the money in multiple ways.
/ Pics from Power Beyond Installation #20
Nuru - Thanks for the good info. I'm going to pick up a 375 BH & power beyond kit for my 3520 Cab tractor this Saturday; will be working on the PB install next week. I want to flip my tires around to get a little wider stance anyways, looks like this will be perfect time to do it.
2016 Peterbilt 389 Day Cab (A62613)
2016 Peterbilt 389...
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
429860 (A61166)
429860 (A61166)
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
