Mowing Belly Mower vs 3 Pt Finish Mower
   / Belly Mower vs 3 Pt Finish Mower #21
im just a cool dude now /w3tcompact/icons/cool.gif
rich
   / Belly Mower vs 3 Pt Finish Mower #22
Sounds to me like some of y'all need to go to tractor driv'n school /w3tcompact/icons/wink.gif
   / Belly Mower vs 3 Pt Finish Mower #23
Hey, FarmerBob, I need all the help I can get./w3tcompact/icons/laugh.gif
Bird
   / Belly Mower vs 3 Pt Finish Mower #24
Dr Dan,
I have an older B7100D with a mid-mower (very difficult to remove for maintenance) and a B2150 with 3 point mower and FEL.
For some parts of my land I prefer to use the tractor w/mid-mower and for other parts I perfer to use the tractor w/rear mower.
Basically, for my property, if I had to have just one, I would have the 3 point mower (as long as I had hydrostatic transmission). I have some steep areas that I go up and down the hill mowing; I would be nervous doing that using the 3-point mower without the FEL for counter-balance. This setup also allows more clearance over humps that I have to cross. When I mow the same areas with the mid-mower, I feel more stable but the mower hits dirt more often on the uneven terrain.
For me, here are the strong points of the mid-mower and 3-point mowers:
Mid-mower stong points: More maneuverable, the 3-point hitch is readily available for most any other task, less space used on the trailer when transporting, less space used when storing the tractor in the garage. Counter-balance is not a concern when on steep grades.
3-point mower strong points: Cheaper, Easier to install and remove, easier (safer) to mow next to the river and next to the edge of steep drop-offs, easier to mow under tree branches. Compatable with other tractors.
Hope this helps,
Kelvin
   / Belly Mower vs 3 Pt Finish Mower #25
i am the eddie albert of tractors so take it easy, i bought a used John Deere 970 and looking at belley mower and need to know if i can add. from what i understand need mid pto and not sure how to figure out if have one.
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
23091 (A55758)
23091 (A55758)
KMC POULTRY HOUSE KEEPER (A58374)
KMC POULTRY HOUSE...
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 66in...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
