Mowing Deck belt
/ Deck belt #1
Toyboy
Hayward Wi
Kubota BX2230D
After following Czbilly's saga about loose pulleys, how many of you release the tension on your mower deck belt over the winter as recommended???
/ Deck belt #2
Toyboy, I had my old Kubota B1550 with a belly mower for about 21 years, give or take a year or two, can't remember exactly. Anyway I always released the belt from tension when I put the mower away for the winter. I would thoroughly clean the underneath of the mower deck, scraping away all the grass and then sprayed a liberal amount of WD40 to the metal area. I had the ORIGINAL belt on the mower when I sold it two years ago. It was pretty nicked up from running through piles of leaves and the occasional twig or two but it never failed me.
/ Deck belt #3
At over $100 for a replacement belt, I will be taking the tension off of mine this winter.
BTW,
The mower stands are nice, but since I have an extra handtruck. I've found that with two patio blocks under it, the deck stands nicely on the hand truck. A bungee to hold the shaft down and a bungee to keep the deck on the handtruck. I was able to take the pulleys and shafts off of mine easily like this.
/ Deck belt #4
I follow srs's routine, along with throwing a coat of paint around the edges where it rubs away. I also check for any cracks that need welded up, a good greasing and a change of blades to ready it for spring.
I use brake spring pliers ( drum brake tool) to realease the spring and to reinstall.
/ Deck belt
Since this BX is new to me, is there a quick & easy way to relieve the belt tension??
/ Deck belt #6
With the deck off, you can push the tensioner pulley with the heel of your foot while you undo the belt from the outside pulley. It's not that easy, two man job.
What I've been doing lately is using a prybar's curved end, the one to take nails out to grab and pull(really hard) on the tensioner spring until the spring is off the hook. I put it back together the same way.
Two people make any job easier.
/ Deck belt #7
Well, half way thru the winter, I read the Manual about relieving the belt tension. So I uncovered the thing and was able to do it with some heavy leather gloves by just pulling the belt over the edge of the outer pulley at the same time turning the blade from underneath. Then came the hard part. To mount the belt took me about 2 hours. I'm 77 years old and 145 lbs and ain't nearly the man that I thought I used to be. Being alone (wife is dead and kids all gone) leaves one to use his head for a change. I wish I had a camera like you other fellas do. Anyway, I took a pipe furniture clamp and found two places where I could mount up without harming anything. And simply stretched that spring out without even a grunt. :cool:
/ Deck belt #8
I've only had mine for a year but did release the tension over last winter. I could not say exactly where I pry without looking..., but I use a 3 or 4 foot length of 2"x2" as a lever to move the tension idler and slide the best off one of the pulleys. It's not really easy, but I have long arms and can do it alone.
/ Deck belt #10
Never have and don't intend to start now; didn't even take my deck off this year.
/ Deck belt #11
I've had my BX1500 for 5 years and never have.
A friend that has had a BX for probably 10 years never has as well.
/ Deck belt #12
I have never released the tension on mine in the three years I have owned it. Original belt still looks brand new. Never did on previous mowers also.
/ Deck belt #14
I use a pry bar and a bolt to keep the pry bar from slipping. give it a little tug and slide the belt over the pulley.
/ Deck belt #15
Say, Kid, that looks quick and simple. Nice picture too. Thanks.
/ Deck belt
Sure does, lots of good replys here from those who do and those who don't. I'll have all summer to think about it. Thanks guys:confused:
/ Deck belt #17
I have done both. First couple years never messed with belt. Last winter I took it off. I agree it a PITA to remove, put back. Its another one of those inconsistant things with the KUBOTA manual. It never explains why.
/ Deck belt #18
I got the mower stands a few months ago, and I got a JD rider a few months back, so I popped mine off for the first time, since I knew it would be off a while.
I just took the right pulley cover off, and pushed on the idler with one hand and rolled the belt off the right pulley with the other. I am not a strong person in my opinion, so maybe I just got lucky.
I am not certain why they recommend taking it off, but I will submit this so that maybe more knowledgeable mechanical folks might correct me, and we will have our answer.
I thought it was so you could lightly grease the shiny parts of the pulleys that the belt keeps polished so that it would not rust in the off season, and possibly over the years, pit the pulley where the belt runs, making a surface eventually that would tend to gnaw on the belt as it runs.
I popped mine off because I didn't want to risk the belt somehow "taking a set" in that position, and thought I was committing a cop-out by not putting a protectant on the pulley face.
It is a cop-out I plan to studiously continue, but the way. It is in a garage, on it's new axles, and in plain sight, so I thought instead, I would simply watch out for rust, and if it happens, arrest it immediately.
There is a process called brinnelling that I will leave to each of you to look up on your own.
Brinelling - Wikipedia, the free encyclopedia
I never have understood when it is likely to happen, and when it is unlikely. But if someone wishes to offer an opinion on that as a possibility, I would appreciate reading it. If no one does, my opinion per the definition on Wikipedia is that it is unlikely.
The source of my confusion is the idea of rotating the shafts of motors in storage for fear of the bearings will fail just sitting there. I may have fallen for a myth so where along the way. But I rotate the shaft on my PTO generator whenever I think about it. At work as I pass a motor in storage, if I am not in a hurry, I rotate the shaft. So, if it is a myth, I am superstitious.
/ Deck belt #19
Bingo!!! I have never do it since 2000..Heck my brother has an older JD 455 from 1998....never done it...
