Saws in the 85 to 90 cc range .
   / Saws in the 85 to 90 cc range . #1
NIXON
West Sunbury ,Pa.
L3130 hst
I'm seriously contemplating a saw in this size . It's down to the following saws 395 xp ,390xp ,and the MS 660 . I had thought of including the Dolmar 7900, but there isn't much of a dealership network in my area ,so it's out of consideration .
I'd appreciate any input from those of You that own any of the above mentioned saws . Thanks .
As LB 59 might say .... BIMP :) (bump for normal posters )
seriously , nobody here uses saws in this range ?
   / Saws in the 85 to 90 cc range . #3
Any of those 3 are good saws. 390 is lightest if you're going to be toting it around much. 660 certainly has a lot of fans. Best advice is find out which dealer you get along with best. Buy accordingly.
   / Saws in the 85 to 90 cc range . #5
Makita DCS 9010/Dolmar 9010 is a good saw.
   / Saws in the 85 to 90 cc range . #6
What size bar will you run? Stihl 044 is still one of my all time favorites and it pulls a 32" even when double cutting. What is the attraction to the 90cc's?
I'll run a short bar ,most likely 24inch with an 8 pin sprocket . I've got an 044 that wears a 20" bar ,and a 372 that wears a 24"bar . This saw won't be a necessity . I just want a fairly beastly bucking saw . :) I guess the attraction is that it's a 90 cc saw . What more can I say :)
Robert N .... You don't by chance frequent AS do You ?
I was toying with doing that to My 044 .
   / Saws in the 85 to 90 cc range . #8
Holy wow. a 24" bar on the 44 must be so fast that you do not need to sharpen the thing. Why would you need a 90cc for that application? I get "the more power the better thing" but it seems like the balance would suck.
   / Saws in the 85 to 90 cc range . #9
I have a Husky 395XP; I've used it for the last year on a Logosol mill to mill about 10,000 bf of SYP and cedar for my retirement home.
It is one hoss of a saw, especially with a muffler mod.
Pretty heavy, however, to use very long in your hands, (unless you're a really big boy).
But, if you are going to be holding the saw, I have read that the Stihl 660 vibrates your hands quite a bit more than the Husky.
Though I haven't used a large Stihl (just a MS290), I do know that the Husky really does a great job of isolating vibration.
I run it with a richer mix for milling (36:1) and have the hi speed adjustment set a bit on the rich side. Just where you can begin to hear it start to '4 cycle' when reved up without a load.
It has held up very well.
Actually it's a 20" bar on the 044 . And , the chain gets sharpened every time I use it :)
Like I said earlier , I don't exactly need it . It's just something that I've wanted to do for a long time . As to balance , if it doesn't feel right , I'll be shopping at Bailey's yet again :)
1995 TALBERT 50 TON LOWBOY TRAILER (A58214)
1995 TALBERT 50...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
2019 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2019 INTERNATIONAL...
202482 (A54757)
202482 (A54757)
NEW IDEA 1 ROW CORN PICKER W/HUSKING BED (A52708)
NEW IDEA 1 ROW...
Online Buyers Premium (A55272)
Online Buyers...
