Just blew a hose
/ Just blew a hose #1
MuncyBob
N Central PA
PT 422
Lost the lift hydraulics due to one of the hoses blowing off the coupler. Off to NAPA today to get a new one...questions is, do you bleed the system just as when changing the filter? I'm guessing I'll have to use the lift several times and then bleed?
Looks like this week is PT repair week for me...just received the new fuel pump last Saturday and a friend will be "supervising" my removal of the carb this Saturday. Hopefully no more vapor lock or surging come Saturday afternoon!
/ Just blew a hose #2
No need to bleed the hose ,just make sure your fluid level is good and operate the lift hydraulics a couple times and it will self bleed
/ Just blew a hose #3
That's correct...
The only circuit you typically need to bleed is the tram pump. Any of the other hydraulic systems (lift, tilt, aux, steering) all you need to do is operate that circuit a few times.
The only time you'd need to worry about those circuits is if you disconnect the lines between the pump and the tank, so that you've introduced air "in front" of the pump. Then, similar to bleeding the tram pump, just pull the spark plug wires and crank it for a minute or two without starting the engine, then replace them, start the engine, and operate the controls...
Air in a line in front of the pump (any hydraulic pump) can "starve it" and cause damage by metal-to-metal contact without lubrication. The tram pump is especially vulnerable because of the swash plates of the variable flow control -- they are extremely close tolerance -- much more so than the fixed output pumps for the other circuits.
/ Just blew a hose #4
Kent. Your note is interesting because I changed out my hoses that drive the wheel motors,and did nothing to fill the lines with oil, nor prime the pumps.
Wonder if I did some damage (I have not issues but....)
/ Just blew a hose #5
The installation instructions for my new wheel motors were to:
(a) fill the motors with oil,
(b) crank the engine over without starting it for one minute -- twice, so not to overheat/damage the starter,
(c) then start it and let it idle for about 15-20 minutes before putting any loads on the wheel motors (i.e. driving it), then slowly operate the controls to ensure all the wheels start to turn at the same time.. They recommended putting it on jackstands for this step.
IMO, all these steps were intended to get the air out of the circuit before putting the motors under load... air will compress and will form bubbles and eventually "foam" as those bubbles pass through the motors or pumps. The more pressure on the system, the more the air compresses, and the more foam you can get as a result of it...
I doubt you did much if any significant damage to your wheel motors, since they should've been full of oil to begin with, but you likely didn't "do them any favors" either.
Did you let the motor idle for a few minutes before driving the tractor? This would have given those air bubbles the opportunity to get back to the tank before putting pressure on the system...
/ Just blew a hose #6
Oh yeah. Idled for a while as I remember. Was totally freaked out about oil leaks so I was double checking every fitting under pressure.
/ Just blew a hose
The mess from the blown hose got me to finally clean the hose area in the front before the new hose install. Now I see I have several hoses leaking slightly....seems the hoses are crammed into areas so tightly that the bend near the connectors has been stressed and 3 hoses are leaking there. I think I will replace them before they too burst apart. I'm thinking replacement with 90 degree elbows may solve the stressed connector problem. Anybody notice this on their hoses?
/ Just blew a hose #8
Anytime you open the closed loop system, you should bleed the wheel motor/pump circuit. thoroughly. The wheel motors have to be turning to pass the air and fluid back to the tram pump bleed port. Sitting at idle will not bleed the wheel motors
Actually, if you do not bleed the system at the tram pump, and since the wheel motor circuit is a closed loop circuit, the air in the system will just circulate around until some of it goes into the case drains on some of the wheel motors, and then to tank. Some of the air in the pump may be sent to the case of the pump along with charge pump excess fluid which is used to cool and or flush the pump case, and then to tank.
/ Just blew a hose #9
Farmall
One thing I want to mention, and the geniuses here will clarify, there are at least two different types of crimped connectors for hoses. One is longer than the other. PT uses the shorter version and designs for it. NAPA in our hood uses the longer version, and I have a few hoses from them on the shelf I cannot use because of the length issue. I ended up going 30 miles away to a different shop that had the shorter hose connectors.
/ Just blew a hose
Farmall
Yep, these are the NAPA hoses. I think it will be cheaper if I just have them remove the longer connectors and put on the elbows. But the leaks I observed are all from the original hoses and it just seems to me that the way these hoses are extremely bent puts too much stress where the hose meets the connector. I have just under 400 hours on the tractor and did not expect to see this many leaks at this time. Granted, they are very minor leaks but still don't want to be out in the woods when one decides to pop off like the one that just did in my backyard.
/ Just blew a hose #11
Have you determined if the leak is from the crimp, or the JIC fitting? There is a type of hyd hose that will allow more of a bend/flex. There are also 45 and 90 degree fittings. You could also have someone bend some steel hyd line to your specifications.
Try this vendor . I just had a hose assembly made up for about half of the local hyd shop.
You simply tell them the hose type, fittings required, and the length.
http://www.discounthydraulichose.com/Hydraulic_Hose_s/84.htm
/ Just blew a hose
Wow! I had no idea there was so much available. Thanks for the link...I think I can get things the way I want them now.
The leaks I have look as though they are coming from the crimped sleeves...coming out from where the hose meets the metal sleeve and it's only on the hoses that connect into a straight fitting but the hoses have extreme bends in them.
/ Just blew a hose #15
OK, Now I am going to show how I shouldn't own a PT
What kind of hose do I want? When I go to Crapa, I hand them my hose the bring me another. When I go to my favorite hose store, there is more of a conversation, but it generally ends with me saying 3000 psi and 2 wire.
I mean, there are a bunch of hoses here that all seem the same, with no real differentiation I can see.
Carl
/ Just blew a hose #16
Around here, SAE 100R2AT is the common hose however i did not like the bend radii for it so i looked for something else. For 1/2" or smaller, I bought SAE 100R16 because of the higher working pressures and for 3/4" and 1", I went with SAE 100R17 to keep my pressure ratings at 3000. From the descriptions, it is hard to tell what is different about them. They both have the same bend radius, made from the same materials, both 2-wire.
Ken
/ Just blew a hose #17
Had my first hydraulic failure this weekend.
Mowing the lawn, and all of a sudden there was a little river of hydraulic fluid purring on my feet.
One of the hoses from the steering cylinder to the steering wheel pump "degloved". The JIC fitting pulled off the hose, taking the rubber sheath off the hose in the process. I screwed the hose back on the fitting so I could drive (carefully) back to the garage.
One of the interesting things was that the hose had almost all the insulation rubbed off where it was zip tied to the other hoses in the center column of the tractor. An accident waiting to happen.
Fortunately, it was easy to just detach the 3 foot hose from both sides and carry it to the local Parker store. I was thankful it was not one of the hoses that ran all the way to the engine compartment. $30 and 20 minutes later, and I am back in business.
/ Just blew a hose #18
This happened to mine. The end pushed off the top of the lift cylinder next to the lift tilt control valve.
Writing on the old Power trac hose reads PARKER NO-SKIVE 421-3 WP 20,7 (3000 PSI) MSHA IC-40/10 SAE100R1AT-3 5 mm. I replaced it with a
PARKER NO-SKIVE 301-4 --- W.P. 5000 PSI ---MSHA IC-40/10 ---- ---- 4-2Q88. TYPE AT --- MIL-H-52471/5 ----- シ X 2W------- SAE 100R2
I know what some of these numbers mean but certainly not all of them.
/ Just blew a hose #19
That looks exactly like my hose looked. I wonder if this is a typical failure mode, or if Power Trac's hose crimping machine is turning out duds.
The steering cylinder doesn't see as much work or pressure as other hoses, so it is surprising to me that it would fail first.
/ Just blew a hose #20
One thing I would add is that I am amazed at how quickly hydraulic hoses rub down. I never thought of that as the hoses appeared to be static, but I guess they pulse more than I can see and I have had a number of wear spots that I have replaced.
Carl
2004 Quick Draw Cover Trailer (A64047)
2004 Quick Draw...
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
GENIE AWP-25S (A63569)
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
TAKEUCHI TL230 SERIES 2 SKID STEER (A64279)
TAKEUCHI TL230...
