Comparison Powershift
/ Powershift #1
rmully
Gold Member
North Carolina
YM 2020
Is powershift worth the extra money and does having it a cause for more mechanical problems down the road ?? Also what do you guys think of a YM2000 vs. a YM2010 ..if you had to choose which would you buy?
Thanks
Robert
/ Powershift #2
The power-shift is worth the money if you're considering a FEL.
The YM2010 is an excellent tractor and the largest two cylinder Yanmar ever produced in the YM series.
/ Powershift #3
Thanks
Robert
Both are good tractors, I would take the YM2010 3cyl power shift over the YM2000 2 cyl gear drive.
Danny
/ Powershift #4
mark777, sure glad to see you post again, hope it is a regular event. And as the dumbest one to post so far, yes the powershift is worth the money.
/ Powershift #5
I sure do like my powershift. So much so that it would hard to imagine not getting it if I had the choice.
/ Powershift #6
Best feature of my tractor besides the diesel engine wouldnt have it any other way now.
I really like the fact I dont have to stop the attachment by pushing in the clutch to move forward or reverse.
Steve
/ Powershift #7
Welcome to the forum. I agree with the other folks.....powershift is worth every penny. I am a relatively new tractor owner.....have driven several in the past but never owned one. I am so glad my 186D has powershift. Makes life real easy with my FEL, saves the clutch. Make sure you have clean fluid......my tractor takes JD 303 or regular Dextron 3 trans. fluid works well. Keep your screen cleaned, make sure your filter is good.....have fun!:thumbsup:
/ Powershift
Thanks everyone ... Powershift it is. One last question ...what is the difference between a YM2010 and a YM2210 all i can see is the the 2010 is 3 cylinder must be more that i don't see.
/ Powershift #9
The 2010 has the 3t82b engine rated at 23hp, built in 80-81, weighs 1920lbs. The 2210 has the 2t90 engine rated at 25hp, built in 77, weighs 2085 lbs.
/ Powershift #11
From reading around, the general opinion seems to be that the 3 cylinders are smoother but that the 2 cylinders have more torque than the same size 3 cylinder.
/ Powershift #12
I have a YM240 (YM2000) 24 hp twin, and a YM186D (YM1510D) 18 hp 3-cylinder.
Pix: http://www.tractorbynet.com/forums/...ner-here-p1530591rym240-ym186d-intarpshed.jpg
The twin seems to have the same torque at any speed and the throttle is just to set how fast you want to do it. Think of how a Caterpillar seems to have useful torque down to nearly zero rpm. It's not *that* strong, but it has the same feeling as you run it.
The three-cylinder, in contrast, wants to be in the upper half of the rpm range to do anything useful. It is very apparent that its torque increases with rpm, and that it is pointless to push it hard below about 2000 rpm.
/ Powershift #13
California,
Since you have both a 2 and a 3 cylinder, how would you rate the difference in smoothness and noise between the two?
/ Powershift #14
The three cylinder is nice and smooth. Like a tractor cousin to a Toyota.
My wife says when she is in the house while I am mowing she can hear it but it is a soothing, non aggravating sound.
In contrast the two cylinder is simply primitive. Each firing has a very harsh clank like striking a manhole cover with a heavy digging bar. Then imagine that at higher rpm.
The instantaneous sound level is so sharp and strong I think it can easily cause hearing loss, same as gunfire. This isn't the exhaust, it is the block or head receiving a heavy impact from the combustion causing a loud clank. Listen to the sound file at the extreme bottom of the page referenced from my sig, below.
These twins are famous for giving the impression that a rod bearing has been washed out and a rod will come through the block momentarily. It is unnerving to work with such a disastrous sound. 1100 rpm would be plenty for my stationary backhoe work (The PTO hyd pump doesn't draw much power) but I use minimum 1200-1250 to get it up to where it doesn't clank so bad. Then over 1800 rpm, it sounds like it will come apart at any second. Roading it at 2400 rpm sounds like horrible abuse, despite that the manual allows it.
They haven't made twins for 30 years. It is an excellent engine but I think this racket is why they retired it.
I recommend hearing protection. Also I feel bad that everyone within a mile, around the ridgetop on my side and the other side of the canyon, is annoyed by it. I hear several tractors in the neighborhood and there is only one that has the harsh clank like this one, and his is only at near-stall. The twins aint some wimpy homeowner lawnmower! :D
I love the 24 hp twin's torque, but downshifting the Powershift on the 18 hp 3 cylinder is about as effective, at least for mowing where its lighter weight is irrelevant.
I still need the larger tractor for its large capacity loader, and for earth-engagement work - box blade etc where its weight gives traction. They both have their place.
The twins are a great value for the money, and a 3 cylinder with Powershift capable of the same work is going to cost a lot more.
/ Powershift #16
California,
That is interesting. I have never been on or even around a running two cylinder Yanmar.
/ Powershift #17
I wonder if that is true of the smaller ones, say the 1300 vs 1301? it would be an interesting comparison.
Mike
/ Powershift #18
Whops.......I was thinking of the YM2210 when I said two cylinder, sorry :)
Mark
/ Powershift #19
Mike
It is especially true of the smaller ones :D!
/ Powershift #20
having used both 2cyl and 3 cyl, you probably should be wearing hearing protection when running either...
2 cyl sounds better to me, 3 cyl sounds like a really loud lawn mower at high rpms.
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
2018 JCB 3TS-8T Compact Wheel Loader Skid Steer (A64553)
2018 JCB 3TS-8T...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
