4944 How big of a brush hog can i run?
/ 4944 How big of a brush hog can i run? #1
ybbob123
I am waiting for my 4944 it just came in and they are tuning and loading the tires. Also this is my first tractor and I am so excitied. Some people say i can run a 6 and some say that is to big i have 40 acres or brush i plan on mowing. any help thanks guys!!
/ 4944 How big of a brush hog can i run? #2
Not familiar with your tractor, but mower size and speed to use are tractor HP dependent. I have used a 6' for years behind both an Oliver 77 with(38hp-drawbar-I believe) and behind my Ford 1700(23hp). The Ford had to be done with less ground speed, but did it. It's all about how fast you want to get done/travel. Which if you go to a 5' you're covering less ground in 1 pass. I personally like the 6' best as an all around size. Cuts alot at a pretty good pace.
/ 4944 How big of a brush hog can i run? #3
I use a five foot with my 3940 and would not hesitate to use a six foot (eventually I will upgrade). The six foot will be a better fit for the width of your machine.
/ 4944 How big of a brush hog can i run? #4
Don"t know the HP of your machine but the rule of thumb is 5 PTO HP per foot of mower and that is a good match it can be a bit lower but do not exceed the lift capability of the tractor.
So a 6 footer needs about 30 PTO HP and the ability to handle the weight of the mower.
thanks guys
/ 4944 How big of a brush hog can i run? #6
Depends on what is being mowed.
I have 40 acres of Midland Bermuda/fescue/red clover/black berry vines/2 types of tall grass (6') /good old prairie grass/other weeds that I mow with a 6' 172 Rhino mower and a 50 hp tractor. It don't want any more especially late summer when the plants get dry and tough. We average over 40" a year in this part of the state so mowing is almost a continual thing.
I tried my neighbors 7' mower he uses with his 80 hp green tractor but to make a good clean cut I had to slow my ground speed to much plus the mower is a little on the heavy side for a 50 hp tractor when the mower has to be lifted on a hard turn.
Also I've found a 1/16 flat edge on the Rhino, on the mower blades, works best for 80 percent of what I mow. I have a old 6' Agri-Cutter that I keep a 1/8 flat edge on the blades for brush/dead wood/larger woody plants/etc. Keep the flats sharp and they cut so much quicker/cleaner.
/ 4944 How big of a brush hog can i run? #7
Recently I have been wanting to upgrade from my 5 ft shredder. I have a 42 HP tractor and looked at a used 7 footer. I backed away for exactly the reasons you said above. I felt that it would strain my tractor, plus excessive wear on the rear lift trying to lift such a heavy mower. I went with a 6 footer , instead, though I have yet to try it out with some real cutting. It rained and I am waiting for the field to dry out.
Alright My rig is 50 horse with 41 coming out of the pto. SO i should def be good with a 6 footer
/ 4944 How big of a brush hog can i run? #9
I have a 5740C Montana and I use an 8ft HD mower that I bought with the tractor back in Feb 2005. I've never had a problem mowing heavy brush nor has it ever strained the tractor. The 5740C has 52 HP at the PTO.
/ 4944 How big of a brush hog can i run? #10
I have a 4340 with 43hp and I use an 8 foot HD cutter.... My tractor runs the mower just fine.... but...... The mower is 2 foot wider than my tractor. I have found this to be a problem on uneven ground. The outside edges tend to dig into the ground.... Therefore I would not get a mower that is much wider than your tractor. A 6ft would have been a better choice for me..... I think this is more important than HP...
/ 4944 How big of a brush hog can i run? #11
R4944hst - run a 6' with no problems
i only paid 14,100 for it brand new 2009 left over :)
/ 4944 How big of a brush hog can i run? #13
Not sure I agree with your last statement, but I do understand why you said it. In your case, you have a little more uneven ground around you then other folks. In my case, the width of the mower really doesn't matter, as long as I don't try to wiggle thru some trees with the tractor that a wider mower won't make. Everything I mow is on the level, so even if I run a batwing, or a ten foot wide mower, it doesn't matter. Seems the O/P might want to consider both reasons, if he has 40 acres to keep mowed.
David from jax
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
CAT 930M (A58214)
CAT 930M (A58214)
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2006 MAC TRI AXLE 37 X 102 DUMP TRAILER (A59905)
2006 MAC TRI AXLE...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2008 CAT 305C (A53317)
