Very tough to get loader off of bx2360 please help
   / Very tough to get loader off of bx2360 please help #21
You may want to read the manual.:thumbsup: It has a procedure for aligning the mounts.;)
   / Very tough to get loader off of bx2360 please help #22
Hold on here-- I agree it should be very easy to take off. One thing I have learned is that when I take my FEL off, I always watch the FEL support stand. watch the feet on both sides and see how much it pushes down on the ground. If the pin is stuck on the right side then the feet on right is not pushing up high enough (hence the reason for adding a shim.) After 2 years of on/off, it pretty comes off so easy from use.
is there a possiblity that the FEL stand is bent a little ?
I know I have bent mine up because of the uneven ground trying to get it on. Getting it off is easy. (Just a thought, but you are putting the stand down right?)
Another question, everyone keeps talking about the paint in the holes, does the pin slide easily through the holes when it is off, no binding? Same clearances on both the mount and the FEL?
I do know some times I have to wiggle mine out but not too often.
As for the comment on flat and level another poster made, there is a difference, and mine actually is hard to get on and off when the ground is level. Odd, one would think it would be easier?
The fact that the salesperson took it on and off without issue leads me to believe that there is NO PAINT (unless it was transfer) and you are binding it somehow while trying to take it off.
Also do not file those holes. Those tolarances are there for a reason and too much (I'm sure you didn't go over board) won't be a good thing.
Also, I do not how your concrete is, so I am not making statements about yours, but I have seen very few contractors that can do a level concrete floor, I've got small swimming pool in my basement, so I know from experience and from seeing too many jobs. So there might be a binding issue. I would try adding small shims to the bottom side of the stand on the sticking side while leaving the good pin in.
I doubt that you have damaged anything where the pins have gon through, I have chased mine around the yard the first couple of times trying to reconnect my FEL, and I never dod any damage that wouldn't grow back.
   / Very tough to get loader off of bx2360 please help #23
You may also want to try looseing the mounts a little,then move the bucket untill the pin moves freely then retorque the mountng bolts in that position.
   / Very tough to get loader off of bx2360 please help #24
see post 21
   / Very tough to get loader off of bx2360 please help #25
see post 21
Again if it came off once easily once, I don't think that is an issue unless there was some loose bolts in the first place.
   / Very tough to get loader off of bx2360 please help #26
YouTube - Removing a loader from the Kubota BX24
If the surface is not very flat, you will get some resistance. Also you may be getting too much or too little pressure on your loader to release pressure on the bolt. Experimentation will tell you which if you determine it is not in a bind from an uneven surface.
I must brag (thats me in the video).. that was my first try, and I just picked a tractor out of the parking lot.. I did not prep it or throw extra grease on the pins at all. No doubt I could shave a few seconds off that time.
I read the manual for the loader when I got home and didn't see any procedure for aligning the mounts
   / Very tough to get loader off of bx2360 please help #29
Over the years I have had dealings with 5 kubotas and all had loose loader bolts or were not aligned properly. The dealers in my area are not very good when they install stuff.
I prefer to get my stuff in the crate and do my own install.
   / Very tough to get loader off of bx2360 please help #30
Good video. My wife and I use to dread taking the FEL off of our BX2200, but the new models are really easy and quick, ours comes off just like in your video also without any special prep.
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2018 JLG SKYTRAK 6036 TELESCOPIC FORKLIFT (A51242)
2018 JLG SKYTRAK...
10 Ft Fork extensions (A50322)
10 Ft Fork...
CATERPILLAR 336FL...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52128)
2022 Gravely...
