Mahindra 2516 hydro toplink question.
   / Mahindra 2516 hydro toplink question. #1
manganos
Close to Petersburg
Mahindra 2516
I'm thinking about adding a hydro toplink and I do not have a rear remote at this time. Anyone use one on their Mahindra and how hard it is to install. I don't want to run a line from the loader...I want to tap into the hydro from the rear. I'm thinking once I get the rear remote I'll find more uses as time goes on.
   / Mahindra 2516 hydro toplink question. #2
I can't help you out with what is needed to get your valve plumbed up as you want,(sorry) but I would suggest that when you do get around to it, install at least 2 valves if not 3. You never have enough remotes. :rolleyes:
   / Mahindra 2516 hydro toplink question. #3
I just finished adding a 2 spool valve, top link cyl and another cyl in place of the lifting arm turnbuckle on a 2615. Works fine. I can help with sources for parts and pictures if you want.
I would appreciate that!!! Thanks!
   / Mahindra 2516 hydro toplink question. #5
would like info also. just got my 2516hst last week and would like to have hyd in the back.
   / Mahindra 2516 hydro toplink question. #6
Don't want to hijack the thread but what did it cost you. I would love to add this to my 2615.
   / Mahindra 2516 hydro toplink question. #7
Total cost was about $850.00. I could have cut that back some, but remember I installed 2 cylinders, used 90 deg. hose end fittings where it would make connecting to the new control valve easier and look better. I had to get the lower link cylinder ends changed, so I had to pay a welder. However, if you shop carefully, you can get some better pricing, as I have found a few better deals on some of the parts since I bought mine. If you do a lot of work with your tractor, the cost is well worth it. I am glad I did the modifications and added this to my 2615.
   / Mahindra 2516 hydro toplink question. #8
I had Ronald at Ranch Hand Supply do my hyd top link and 2 spool for backhoe attachment. I think he was going to make up a kit for the 2615. I am very happy with the setup
   / Mahindra 2516 hydro toplink question. #9
Yes, me, too! Can you post the pics here in this thread? Thanks.
   / Mahindra 2516 hydro toplink question. #10
Here are a few quick photos of my 2615 HST with FEL. I'll post some better ones soon with more details.
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
2014 VOLVO VN SERIES DAY CAB (A50854)
2014 VOLVO VN...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
