Subaru ATF (OEM) color
/ Subaru ATF (OEM) color #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I started the process of the drain/refill the ATF on my wife Subaru forester today.. Does anyone know what color the original ATF is suppose to be? What came out was burnt brownish looking..
Brian
/ Subaru ATF (OEM) color #2
Our Legacy was filled with Red ATF.
Cant say for sure about the forrester but id assume it was the same?
Maybe some fancy synthetic ATF would be a different colour but i have never seen it.
Did it smell burnt?
Did it smell burnt?
I would also assume the Legacy and forester has the same ATF.
it did not smell burnt, just had that odd color.. The vehicle only has 35k on it as well..
brian
/ Subaru ATF (OEM) color #4
brian
ours was a couple generations older than yours, so the current OEM could be different. but id assume it isnt.
If it didnt smell burnt i wouldnt sweat it. Just add fresh ATF. i think the factory "high performance (STI)" ATF is more pink the blood red. I always ran regular brand name ATF (red stuff) with no issues.
By no means im not questioning your ability, but its happened before where people have dropped the front diff lube by mistake. That would be a light brown/black gear oil colour.Subie trannies are quite long and mistakes can happen if your not familiar.. just throwing that out as a possible solution, no offence intended
<deleted text>
I can see that happening. BUT I had just drained the front (and rear) differentials early that day.. The front differential drain plug was marked 'diff' (which is nice of subaru to do).. The front diff also take a T-20ish torx socket..
I also double checked the front diff and transmission levels to make sure they were not overfilled/empty.. lol
Brian
/ Subaru ATF (OEM) color #6
Brian
:D
looks like you got it under control. ive been there on the second guessing thing:D
low miles and a weird colour, but not burnt, sure is different:confused:
maybe post this over on scoobynet.com or another subaru form for confirmation of the oem colour?
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2018 Trail King Lowboy (A63689)
2018 Trail King...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2021 Ford F-150 4x4 Single Cab Pickup Truck (A61573)
2021 Ford F-150...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
