Beware the safety switch
/ Beware the safety switch #1
MESSMAKER
Bluegrass,KY
DK4710SE
Just a heads up.This has happened to me twice. It has brought things to a screaming halt. If you are doing loader work in high weeds, you can get debris in the safety switch located under the frame below the seat. I have twice had a leaf the size of a fingernail keep the tractor from restarting. It gets wedged between the contact points of the switch. Look here first if your tractor won't turn over.
/ Beware the safety switch #2
Thanks for that. Any pictures?;)
/ Beware the safety switch #3
hmmm...safety switch...hmmm
I'll take a bypass on that...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61573)
2020 Mack Anthem...
(2) 380/85R28 TIRES W/ (10) LUG WHEELS (A64280)
(2) 380/85R28...
