Tractor Sizing Rules Of Thumb For Tractor Size, etc?
   / Rules Of Thumb For Tractor Size, etc? #1
adamjthompson86
Thanks all for your help in this thread in helping me understand why utility tractors are more expensive than riding lawn mowers and why I can't compare their horsepower numbers. I have some follow-up questions, now:
Are there rules of thumb for how much horsepower you need for certain tasks or attachments? (i.e. X HP for a 60" rotary cutter, X for loading dirt, X for towing a wagon.trailer with x pounds on it, X for digging up rocks with a backhoe, etc) (I realize that power is not the only factor - using a backhoe, for example, requires a heavy enough tractor to keep from being dragged around).
Without a point of reference, HP ratings aren't very helpful. :p Are their accurate ways to know if a tractor has enough power to do certain jobs, or is that something you more have to learn and guess based on your experience with different tractors?
Are horsepower ratings a reasonably accurate way to measure utility tractors and compare them to each other?
Thanks!
   / Rules Of Thumb For Tractor Size, etc? #2
For me, I picked the HP for what I wanted to do. Pull a Six foot bush hog without a problem. So that put me in the 40HP range. Now I can cut my 6 acre field in 2 hours instead of about 8 hours with a Craftman 26 hp 54in cut lawnmower.
   / Rules Of Thumb For Tractor Size, etc? #3
Honestly, I believe that you must pair the tractor to intended use. If you have a 1 acre lot, then a Grand L Kubota probably isn't a good idea.
Most of the compact and sub-compacts are very well designed in terms of horsepower and weight to impliments available for them. I've heard that rear mount mowers should be 5 hp per foot of width.
Tillers etc are going to be limited by 3pt lift capacity and HP. Although a sub-compact tiller will be weight and power matched given it's size, unless you try to push it.
Loaders and BH's have specs like break out force, digging depth, and overall weight and capacity..Those are good for comparison.
I wouldn't get too attached to horsepower. Worry more about what you intend to use it for. Do you need 4x4? What kind of trans is going to work best for your work..Etc.
Don't buy too big, and don't buy too small...
Let us know what you're going to be doing....I'm sure you'll get more opinions than you can digest.
   / Rules Of Thumb For Tractor Size, etc? #4
"Do you need 4x4?"
Of course you need 4WD, even if you don't you do! :laughing:
   / Rules Of Thumb For Tractor Size, etc? #5
I would say weight and HP and whether a tractor is 2 or 4wd sometimes referred to as MFWD (Mechanical Front Wheel Drive).
The number you will hear quoted a lot is 5(PTO)HP per foot of mower and that is a little flexible.
When it comes to a Box Blade (BB) you should get it by the width of the tractor wide enough to cover the tire tracks.
Scraper Blade is usually get it about 1 foot wider than the tire width so you can angle the blade and still cover the tire track.
I am sure others can throw in more.
   / Rules Of Thumb For Tractor Size, etc? #6
How did you know that you need 40HP to pull a 6' rotary cutter? Is there a chart or formula or something?
The number you will hear quoted a lot is 5hp per foot of mower and that is a little flexible.
That sounds helpful. :) I'm guessing that's 5 PTO HP, not total HP?
Are there formulas for other tasks like lifting weight, towing weight, etc?
   / Rules Of Thumb For Tractor Size, etc? #9
I have friends who have tractors, and I asked the dealers what they would recommend for a 6 foot bush hog. Everyone I talked to come up with around 40HP. Oh and from reading on here. No charts, just other peoples experience.
I'm gathering that buying a tractor is a little less scientific than buying a vehicle. Instead of comparing MPGs, 0-60, and crash ratings, it's more like...
"Hey Bubba! Y'reckon this here tractor'll till up that thar plot o' land?"
:D:D:D
   / Rules Of Thumb For Tractor Size, etc? #11
You got it.
I looked and asked question for about 2 years before I bought mine. So far I have not been disappointed with what I bought. There are alot of people on here that have a lot of knowledge. Just dig and read you will find the info you need. Now that I have the tractor I should have bought one 4 years ago.
   / Rules Of Thumb For Tractor Size, etc? #12
:D:D:D
Kinda like that:D... Not a science, just buy what you are going to need. A dealer and others experiences will converge on the right machine. Just take your time.
   / Rules Of Thumb For Tractor Size, etc? #14
Thanks!
Find good info here
http://www.tifton.uga.edu/eng/Publications/farm tractor.pdf
   / Rules Of Thumb For Tractor Size, etc? #15
That is correct.
   / Rules Of Thumb For Tractor Size, etc? #16
You're getting it. Determining tractor requirements is about using your assets around you, dealers, friends and forums. There isn't a one tractor fits all. A tractor is a tool just like the wrenches, screwdrivers etc in a tool box i.e. small, medium and large. When buying a tractor you need to determine what is it's purpose, to mow a lawn or plowing 1000 acres. How fast do you want to complete the task. Then on top of that you now have to compromise on what you want/need and how big your pocket book is. Then to add more confusion is what implements you need/want. Sometimes the tractor is the least expensive part of the purchase. So yes it can be very confusing and I think that most people will agree that you need to take your time before you make that purchase.
So maybe buying a tractor is more of an art than a science.
   / Rules Of Thumb For Tractor Size, etc? #17
Just ignore the engine HP. As posted in your other thread, that's gross HP and not really a good indicator of usable power.
As far as lifting and towing...well, what would you need to lift and what would you need to tow? More lift capacity and heavier towing requires a larger tractor.
I don't tow, but for lifting I'm more interested what the loader can do a foot or so off the ground rather then at maximum height. Heaviest thing I've ever lifted was a 650 lb rotary cutter out of the bed of a Ford Ranger. That was done with a small Deere 670 with about 700 lbs maximum capacity at maximum height. I was more concerned about how high the loader could go when offloading that cutter. Breakout force is important too, if you intend to dig into piles of dirt and mulch.
So, determine what you think you need.
BTW, the 5 PTO HP for foot of cutter is very flexible. You can easily drop down to 3 or 4 but it's going to be slower going.
   / Rules Of Thumb For Tractor Size, etc? #18
If you are useing the tractor to tend to some crops, etc, then 1 hp per acre of land is a good rule of thumb. This is just a generalization as some types of crops and usage will require more hp than others. I like having several tractors of different sizes. This is especially nice if you enjoy your "seat time" as I do, but dont always have a lot available. The smaller the tractor, the more "seat time" you get. For example, sometimes, on a nice winter day, I will use my little 10 hp, Farmall cub for plowing snow from the driveways around my house and barns, which stretches that job out to an hour or more. When time is short, I will use my 43 hp, 4wd JD, which usually gets that job done in less than 15 minutes. Any discussion on tractor sizes has to consider both time available and type of job. The 1 hp per acre rule will put you pretty close to the most efficient tractor hp for many tasks.
   / Rules Of Thumb For Tractor Size, etc? #19
Most implements will have a range of HP need to operate the implement.
I just bought a 60" rear tine tiller. It has a needed hp of between 25 and 40 hp. My tractor is a 35 hp Mahindra and it runs the tiller with no problem at all. So check with the dealer who is selling the implement and check to see what HP is needed to operate the implement.
Don
   / Rules Of Thumb For Tractor Size, etc? #20
I asked and asked prior to purchasing our first tractor. Of course I read this site and welcomed the wisdom I gleened from it. Two mistakes I made due to naivete; 1) had to sell the first tractor because I needed a front mounted snow blower to take care of the 1 1/2 mile road during the winter and the original tractor didn't have the requisite midPTO for the snow blower. (Thankfully I'm retired and could spend all day on the tractor 4 days a week when I used the rear blade and front bucket.) 2) Didn't get the rear tires filled.
A friend told me a long time ago when buying a camera to determine what I wanted it to do, find a camera that would do that and buy the next model or two up so I wouldn't have to upgrade as my desires changed. That is what I recommend with tractors also. Our first tractor was a basic Kubota L3400 that worked fine except for the lack of the mid PTO. We upgraded to the Grand L model and I discovered what a joy it is to hook up the implements because of its adjustable three point hitch. It came with filled rear tires and the stability they provide is phenominal.
I would have liked a cab model as snow removal in single digit weather gets chilly but we couldn't afford the luxury. (Just another reason to break out the cold weather hunting gear that sits in the closet most of the year.) The filled tires take up some power and after getting used to the 3 additional HP from the previous tractor, I would have wanted one with 3 more. Do I really need it, no, but you should know men and horses.
Look at the construction of the various models, such as welds, axel sizes, how the hydraulic lines are ran (are they protected). There is much more wisdom available on this site than what I can provide. Dream big and ask your wife for a few grand more, then have fun!
2017 Ford F-250 (A55973)
2017 Ford F-250...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
Enclosed Service Truck (A55788)
Enclosed Service...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
