Can I cap it?
/ Can I cap it? #1
desert trader
Member
Shoshone,Idaho
Massey Ferguson 165
I have a MF 165 that I am putting a pto hyd pump on to get a faster loader speed.The loader is now hooked to the auxilery hyd pump on the lower left side where the pto lever is. My question is scince I don't need the hyd from the tractor can I just cap off the hyd outlet and inlet that it is hooked to on the tractor?
/ Can I cap it? #2
ONLY IF YOU HAVE DISCONNECTED THE PUMP FROM ITS DRIVE......if pump keep turning it will take severe damage.......will need oil supply for cooling and lube...
/ Can I cap it? #3
I believe you will need to remove that pump, as it is still turning when the engine is running. Remove the pump and put a cover plate in it's place.
/ Can I cap it?
Can't remove the pump without splitting the tractor therefore the reason for the external pto pump.
/ Can I cap it? #5
Then just plumb the pump outlet (use large size pipe or 1-wire hose) to tank, and let the inlet stay as is...then oil will just circulate with minimum pressure....a little temp increase might be the result....just keep it under control....
2019 GMC Sierra 2500,4x4 (A62679)
2019 GMC Sierra...
2022 EZ-GO ELITE...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65583)
IMPORTANT PLEASE...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2008 BMW 3 series Passenger Car, VIN # WBAWB33568P132774 (A65563)
2008 BMW 3 series...
