letters on subplate
/ letters on subplate #1
jinmared
Goldendale,Wa
Jinma 354 fwd
I have a station DO3 subplate it has a letter on each end they are T B A P does
anyone know what they mean?
/ letters on subplate #2
T tank return
B port to rod side
A port to capped side
P pump supply
Usually A and B can be swapped with each other...but some valves can have larger cavities for A, capped side, because capped side of a double action cylinder have higher flow than the rod side....
/ letters on subplate #3
On the subject of D03 sub plates. Does anyone know where to get a flush block for that plate? I am getting ready to put oil in a winch system I built and I would like to by pass the motor, easy , and bypass the valve. Need a flush block for the valve plate.
/ letters on subplate #4
Daman Manifolds makes them. Not sure if they will sell to individuals but there website is: Daman Manifolds
I have have good responses in dealing with them. If they won't sell direct they should be able to tell who is a distributor in your area.
Roy
/ letters on subplate #5
Perfect Thanks
thanks for the help on my subplate letters akkamann
/ letters on subplate #7
If you are talking about hydraulic winch motor, why not fill the hyd motor with fluid and hook it up, and it will complete the prime once connected.
/ letters on subplate #8
It's not the prime I am concerned about . It's debris. The motor is a fairly precision piece of equipment, similar to a pump. I also have a solenoid valve switching the flow. I feel the solenoid valve is more sensitive to debris than a mechanical valve. So I want to flush the lines with the motor and the solenoid valve out of the circuit. Disconnecting the lines from the motor and using a connector between them the motor circuit is complete except the motor is not there. Replacing the valve with a cover allows bypass across the manifold ports.
I am using a cover that provides P to A and B to T connections.
/ letters on subplate #9
Depending on the length of the lose, you could pull a lint free rag balls through the hose several times. Use a vacuum to get the string through
1989 Cheetah Chassis Corp 40ft. 36 Ton T/A Container Trailer (A64556)
1989 Cheetah...
3/8" Quick Attach Blank Plate (A66408)
3/8" Quick Attach...
(6) 4ftx12ft platform grating  (A62679)
(6) 4ftx12ft...
3Pt Poly Red Ball Tank (A66408)
3Pt Poly Red Ball...
Kinze KPM3 Planter Monitor (A65640)
Kinze KPM3 Planter...
2005 INTERNATIONAL 9400I (A65643)
2005 INTERNATIONAL...
