Fence post in 5 easy steps.
/ Fence post in 5 easy steps. #1
TheRealBuzz
ON. Canada
Massey Ferguson GC2410TLB, Past: Kubota BX1800
Step 1. Dig a nice hole just the perfect size with a post hole auger.
Step 2. Get post hole auger stuck in some buried cedar rails.
Step 3. Get auger out by digging massive hole with backhoe.
step 4. Place post in over sized hole.
Step 5. Back fill hole with FEL.
Done!
/ Fence post in 5 easy steps. #2
You make it look fun! I'll try it if I can just find some buried cedar rails.:p
/ Fence post in 5 easy steps. #3
:laughing::laughing::laughing: Not laughing at you, laughing with you:D
Man that sucks.
On the plus side, you got to play with all your accessories:thumbsup:
/ Fence post in 5 easy steps. #4
Good job:thumbsup: Now you need some good brace posts so it won't pull out of the ground when you put a gate and some fence wire on it.:D
/ Fence post in 5 easy steps. #5
I drilled right along side an old 2" pipe oil line, from an abandoned oil well, that runs across the property. My version of a backhoe was an 18" pipe wrench, and a 4' cheater pipe, and lots, and lots of of turning of the auger...
/ Fence post in 5 easy steps. #6
Just think of the fun you could have had with a gas line!!!
I just got my GCTLB after having a BX1800 for a few years and was not used to having a backhoe at my fingertips. So when I got the auger stuck I started thinking about how much work it was going to be to shovel down around the head so I could detach the bit and try turning it back out when I realized:
"What the heck am I doing? I've got a backhoe!"
/ Fence post in 5 easy steps. #8
3* Step 3. Get auger out by digging massive hole with backhoe.
Done!
3*You could have avoided steps 1-4 by making this step 1.
You could have saved your self all that work if you would have just used the BH in the first place.
Unless you need a lot of holes dug for many post I see no sense in a PHD if you have a BH.
/ Fence post in 5 easy steps. #9
Because a post hold dug with a backhoe needs a bunch of compacting when back filling as opposed to a properly sized hole dug by an auger.... that's why. ;)
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
(INOP) 2022 MACK MD6 WATER TRUCK (A65054)
(INOP) 2022 MACK...
2021 KUBOTA KX080-4 SUPER SERIES 2 EXCAVATOR (A65053)
2021 KUBOTA...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
Ground Protection Mats (A64194)
Ground Protection...
