3520 my 72mmm raises & lowers to fast
   / 3520 my 72mmm raises & lowers to fast #1
bud4410
kingsville, maryland
jd 3520 HST open station turf tires air seat jd 997 ztrak 72"
hi guys, maybe you can give me some advice. on my new 3520 with 72D mmm the mower deck seems to raise and lower entirely too fast. it just about slams at the top and bottom of the travel. even if the motor is at idle. does yours act the same way? is there a fix for this condition? my old 4410 had two hyd. lines running from the rear of the tractor to the lift cylinder for the deck. this tractor only has one. ?????? please give me some good advice. thanks in advance. sincerely, bud
   / 3520 my 72mmm raises & lowers to fast #2
Do you have the independant lift kit, or it is connected to your draft arms?
   / 3520 my 72mmm raises & lowers to fast #3
Hmmm, I have about the same setup (3720 with 7 Iron 72" mmm) and the deck lift cylinder has two lines connected to it from the rear remotes. My deck does not move up/down all that fast.
   / 3520 my 72mmm raises & lowers to fast #5
The solution is to install a restrictor in one of the lines to slow the cylinder down.
   / 3520 my 72mmm raises & lowers to fast #6
Seems a bit peculiar as that 72D is a very heavy deck, and I have a 72 7Iron non "D" deck and I have not seen that issue. I think KennyD is right. Also check with your local dealer 's service shop about options.
   / 3520 my 72mmm raises & lowers to fast #7
I have the 72D MMM on my 3520 and I experience the same concern of slamming. As I recall it only has one line to the cylinder. Been trying to modulate the pressure by moving the contol lever slowly during lifting/lowering. Also, the cylinder always seems to leak down as I must always lift the mower deck eveytime I get into the tractor.
The only flow restrictor I recall seeing was on the front hyd lift cylinder used for the plow.
   / 3520 my 72mmm raises & lowers to fast #8
All right...someone else needs to learn to use JDParts;)
Below is what the lift cylinder should look like if I searched correctly. Part #12 is listed as a "Orifice". That should modulate the speed. Either it's not there or it's to big.
   / 3520 my 72mmm raises & lowers to fast #9
You beat me to it. My guess is someone did not put in in when they put on the deck.
   / 3520 my 72mmm raises & lowers to fast #10
Looks like a very easy fix to insert the orifice part.
(2) DOUBLE AXLE FENDERS (A54756)
(2) DOUBLE AXLE...
New/Unused 30in Rolling Service Cart (A54865)
New/Unused 30in...
UNUSED LANDHONOR LHR-SB2T3M CHAIN LEVER HOIST (A54757)
UNUSED LANDHONOR...
2017 Kia Sorento SUV (A53424)
2017 Kia Sorento...
2018 FORD F150 Ext Cab 4X4 Pick-up Truck (A53422)
2018 FORD F150 Ext...
