Bobcat brand filters
/ Bobcat brand filters #1
Massey1010
Member
Willamette Valley
The Bobcat dealers in my area used to sell Kioti equipment until they were bought out by PAPE equipment about 6 months ago. Now the nearest dealer is 99 miles away. The Bobcat dealer says that the Bobcat branded filters will fit my CK20. Is this true?
I guess the filters must be the same since they use them for the Bobcat branded Daedong tractors.
/ Bobcat brand filters #3
Same motor and basically the same tractors. The filters should be interchangable. However, Bobcat's price could be different.
Stopped at the Bobcat dealer today and picked up all the filters to do the 50 hour service. The filters were all the same except for the fuel filter. The original one has some sort of rubber end where it plugs into the socket whereas the Bobcat one has a metal end. I don't know if I just got the wrong filter or if the newer engines take a little different fuel filter. The prices for the Bobcat brand filters are as follows:
Trans Filter #6695914 $12.73
Hydro filter #6695918 $15.92
Fuel filter #6694422 $2.77
Engine filter #6694509 $5.72
Total $37.14
/ Bobcat brand filters #5
Wonder why Bobcat filters are cheaper. Just the transmission filter alone from Kioti is $11 more than you paid for all of your filters combined. Surely Kioti dealers can't be marking them up that much.
/ Bobcat brand filters #6
Those filter prices seem cheap to me. My JD hydrostat filter cost $94! I bought a dinky engine oil filter for my Kawasaki Teryx and that was $16.
/ Bobcat brand filters #8
Actually they are pretty close to what I paid Wallace for the same items. Just pennies difference
Ok, looks like I did get the right fuel filter from the Bobcat dealer but I didn't notice that the top cap of the original filter was still stuck to the filter housing socket. Apparently this is a common problem when removing the old filter according to a Kioti dealer. All is good.
Picked up some more filters from the Bobcat dealer. The prices have gone up a bit.
Trans Filter #6695914 $13.00
Hydro filter #6695918 $16.23
Fuel filter #6694422 $2.83
Engine filter #6694509 $5.83
Air Filter #6673752 $12.79
/ Bobcat brand filters #11
Ummmmmm I need to find a Bobcat dealer to buy my filters from....dang.
BTI
/ Bobcat brand filters #12
That hydro filter price seems very low. I thought those cost closer to $40-50.
/ Bobcat brand filters #13
I paid nearly $60. for my Hydro filter, a NAPA Gold is less than $12.
/ Bobcat brand filters #15
I don't know for sure if Kioti follows the same type of hydraulic filter requirements as does Scag mowers, for instance, but Scag say to NEVER use an automotive type filter for the hydraulic filter replacement on their mowers.
I suspect the filter level of the automotive and tractor professional mowers is somewhat different if not completely different, hence the big $ difference. I sure wouldn't want to use a cheap quality filter on my tractor and have something go wrong. BTW, I'm not saying the Napa filter is junk, I do not have anything to make an apples to apples comparison from- and unfortunately I think the filter manufacturers like it that way- especially companies that sell their own brand of high priced filters- like Kioti, Deere, etc.
Anyone know for sure- facts vs. conjecture?
/ Bobcat brand filters #16
Bobcat CT 230 exact same as CK30 HST?
If so then the filters should be a dead-on match?
Maybe there is something not so obvious that makes them different? Warranty issues perhaps? Would not mind getting the lower price for sure..
Anyone?
/ Bobcat brand filters #17
Yes...x2.
Massey's prices are quite good. Glad to hear that since Pape quoted me
$100 for a CT230 parts book......in PDF!
Kioti's warranty is longer, and their air filter housing does not have an
inner filter. Of course, you can buy the inner filter from Bobcat.....it
goes right in.
/ Bobcat brand filters #18
goes right in.
So should we be running the Inner filters in our CK30's? More filtration sounds better; unless it won't let the engine breath easily. I'm at 5,000 feet-so the air is thin already. Can you elaborate please on the inner filter's purpose on BobCat?
Thanks
/ Bobcat brand filters #20
Some tractor makers use 2 air filters; some don't. The Kiotis don't use
the inner filter, and I was surprised that Bobcat did. Donaldson makes
the housing....the exact same unit for both. I don't use the inner filter
on my Kioti, but it can not hurt. I don't operate much in dusty environments.
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
Caterpillar 143H/163H Motor Grader Service Manuals (A63117)
Caterpillar...
CASE INTERNATIONAL 183 - 6R DANISH TINE CULTIVATOR (A63291)
CASE INTERNATIONAL...
Caterpillar 330BL Excavator Service and Parts Manuals (A63117)
Caterpillar 330BL...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2006 Chevrolet Silverado 2500HD Ext. Cab Knapheide Service Truck (A61573)
2006 Chevrolet...
