Log Splitter and JD Power Beyond
/ Log Splitter and JD Power Beyond #1
birchpoint
Bracebridge Ontario
John Deere 4300 Compact Utility (1998)
I own a (1998) I beleive JD 4300 Compact Utility tractor without rear hydraulics and am thinking about a Wallenstein 3 pt. hitch log splitter attachment. Can anyone advise me on whether the JD Power Beyond is the best way to go or a PTO pump from Wallenstein? I am also thinking about the Wallenstein Backhoe attachment as well.
Thanks
Scott
/ Log Splitter and JD Power Beyond #2
Thanks
Scott
Welcome to TBN:D
The PB kit would fit the bill perfectly, and is cheaper that the PTO pump.
That's great thank you. Am I right to assume that I will still be able to lift and lower the 3 pt hitch with the log splitter working and hooked up to the PB?
Thanks
/ Log Splitter and JD Power Beyond #4
Thanks
Yes. There are two returns with the PB kit, one feeds the 3PH-and one goes directly to the tank for use when a backhoe is mounted. Diagrams are available at www.jdparts.com
/ Log Splitter and JD Power Beyond #5
Dont mean to dig up a super old thread, but it's related I think....
the PB kit on a 1026R, would this also support a wood splitter? Something like the WX310?
/ Log Splitter and JD Power Beyond #6
Yes, but it will be SLOW:thumbsup:
/ Log Splitter and JD Power Beyond #7
We've discussed 3 point splitters in a number of other threads. The 1026 will have between 3 and 4 gpm available. With a two way splitter and a 3" cylinder like my PowerHorse 13 ton, you will be able to make a split every 10 seconds or so. However, with a one way 4" cylinder splitter like the the WX310, it will be way too slow.
If you need the larger capacity on a small tractor, you will need a PTO pump or a stand alone splitter.
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
24ft Flatbed Gooseneck Trailer (A61166)
24ft Flatbed...
UNUSED RAYSKY RM87-96 MOBILE TOILET (A62131)
UNUSED RAYSKY...
2025 Spirit Electric Scooter (A61569)
2025 Spirit...
2023 Chevrolet Express Van, VIN # 1GCWGBFP8P1104620 (A61165)
2023 Chevrolet...
