Removing bucket from CT230
/ Removing bucket from CT230 #1
Grand_Pooba
Wyoming County, NY
Bobcat CT230 & John Deere X324
Has anyone detached there pin on bucket? I would like to take my bucket to a welder that I know to have a couple bucket hooks welded on. It appears to have a retaining bolt at each pin on the inside of the loader arms....so take out the bolt and tap the pin out from the inside. Am I assuming correctly?
Thanks.
/ Removing bucket from CT230 #2
I have, and never will again. It comes off just as easy as you typed, but reinstalling is a pain. I now see why there was hammer marks on the bucket bracket from the dealer. I had to use a 4 foot bar align the bottom holes, the fit was just too tight. It took me about a hour and a few magical words. Remember to align the retaining hole before reinserting the pin, you cant turn them once installed.
/ Removing bucket from CT230 #3
maybw while your there have him weld on a quik attach plate and convert the pin on to a bobtach ;)
I knew I was going to get at least one wise ***** comment about a bob-tach:D
This should be the only time I'm going to need to take it off. (I hope)
Has anyone welded hooks to their bucket? I need to decide if I'm going re-enforce the top edge or not. The rolled tube on the top edge seams very beefy. Any thoughts?
/ Removing bucket from CT230 #5
Well, I have the Bobtach and 68" bucket. Here is the hook I welded onto
the Bobtach frame. I do my other tractors in a similar way with a
reinforcement plate and a mount to the back center area. This gives
maximum lift and minimum chance of distorting the bucket, versus welding
a hook on the lip, or the sides of the bucket.
I also use 1/2" plate with a slot in it to hold the chain. This is secure
enough for grabber-style chain, yet allows you to drop the chain from
the driver's seat by curling the bucket.
/ Removing bucket from CT230 #7
Can you snap a pic of your install. I just happen to want a hook and also just happen to have some of those hooks in the basement.
/ Removing bucket from CT230 #8
just a thought....... at some point (if you use things hard) I am sure you will need to have that bucket off again to have a weld rewelded or reinforced, so you may be taking it off again.
/ Removing bucket from CT230 #9
VOLVO L90E WHEEL LOADER (A64279)
VOLVO L90E WHEEL...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2012 Ford Expedition SUV (A61574)
2012 Ford...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
Topsoil Trommel (A57453)
Topsoil Trommel...
