adjusting 3pt to lift higher
   / adjusting 3pt to lift higher
thanks Roy, i don't mind supporting the local dealer, but i also like finding bargains!
   / adjusting 3pt to lift higher #32
IMO, buying the tech manual isn't supporting the local dealer. Buying parts, tractors, filters, attachments, etc, thats supporting the dealer. The tech manual is a means to figure out which things need to be bought in order to support the dealer.
I bet if you offer this guy $10 or $15 for it he'll bite too:
One CD
   / adjusting 3pt to lift higher #33
I think you should go for the best deal you can find!!!
My only recommendation is to stick with a factory manual and not one of the aftermarket manuals.
When I bought mine in 2001, there wasn't many choices where to get one.
i didn't know that there were factory/aftermarket versions. and i suppose that they all use the TM1677 part # designation?
   / adjusting 3pt to lift higher #35
They're all the same. I don't know if Roy is opposed to the "pirated" version, that would be a personal decision, but the eBay versions are the same as the JDParts ones.
I'm personally very much against pirating software. I have no pirated software anywhere in my use. But that is because people make a living off selling the software. JD does not make a living selling tech manuals. They make the manuals for their own dealers to turn around and make money off the consumer. I find it obnoxious of manufacturers not to offer the tech manual with the equipment at the price of printing it. And in the case of the $60 CD, not offering it for FREE.
   / adjusting 3pt to lift higher #36
For the greatest height when lifted put top link in top hole on your tractor.
DevilDog
   / adjusting 3pt to lift higher #37
DevilDog
And here I thought it would be in the bottom holes. :confused:
Shortening that top arm would raise the attachment higher too. Looks like it is not a factory supplied top arm and may not adjust shorter.
i have the top link in the middle hole based on the manual's load rating (medium duty, middle hole). it is not a factory link, it will go shorter, but then it messes up the angle of the blade.
i still have to check the specs provided to me earlier in the thread, and this isn't a huge issue, was just curious if there was anything you could adjust on, and apparently there are a couple of things.
thanks for all the replies on this topic.
   / adjusting 3pt to lift higher #39
No, I wasn't thinking of "pirated" manuals. There are other non-factory manuals available...Tractor Supply sells 'em (or used to). These would be similar to a Chilton manual, but not near as comprehensive. The name ITC seems to ring a bell (as a publisher).
I'm just suggesting that you stick with the factory authorized manuals.
Even the factory manual presupposes the user has a degree of mechanical apptitude. They'll help you with specs and tests and such, but they won't make a mechanic of a person with no experience. In other words, if you don't know how to install rings (on a piston) or use a torque wrench, the manual isn't going to help.
i'm not as good of a mechanic as i should be. i've rebuilt several engines to varying degrees...from simple re-ring/valve job, to complete rebuild/oversize bore (i didn't do the boring tho). but i forget alot because i don't do it that often. my dad used to do engine stuff for a living, then machining, so he's there to help me out.
just today, i was trying to remove a drain plug and the allen head was stripped. wasn't enough sticking out to grip it w/ anything, so i tried a chisel to get it turning. was just peeling it away. i had to drill it and use an easy out. nothing is ever easy...luckily i have just enough mechanical ability to be dangerous.
CATERPILLAR CB24B SMOOTH DBL DRUM ROLLER (A52705)
CATERPILLAR CB24B...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2016 UTILITY 53FT REEFER TRAILER (A54607)
2016 UTILITY 53FT...
John Deere 7130 (A53314)
John Deere 7130...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
