MM BF restoration-more progress
/ MM BF restoration-more progress #1
flusher
Super Member
Sacramento
Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
This continues a couple of previous threads.
http://www.tractorbynet.com/forums/...nneapolis-moline-bf-restoration-progress.html
http://www.tractorbynet.com/forums/...eapolis-moline-bf-restoration-continuing.html
I spent most Oct-Nov09 cleaning and spray painting parts. Then the weather turned damp and cold so I put the spray gun away and started working on the hydraulics and the electrical system.
This MM BF has the HJK hydraulic lift system consisting of an Eaton hydraulic pump that runs off the timing gear on the front of the engine,
and a hydraulic reservoir that contains the control valves that operating the hydraulic cylinder that moves the 3pt hitch up and down. As near as I can tell from the MM manuals, this system is pieced together from parts of the MM Uni-matic hydraulic system that MM developed in the 1950s.
I disassembled these components, thoroughly cleaned out the gunk and reassembled with new seals where needed.
Here are some shots of the hydraulic reservoir and the control valve that fits inside
As usual when restoring these old tractors, you get slowed by dumb things. In this case it was stuck hydraulic fittings that attach the hydraulic hoses to the reservoir. I finally had to cut the hoses (they were trash anyway) and weld a piece of 1/2"x1" bar stock on the stub so I could get leverage to unscrew these babies.
You need to be real careful when applying the muscle to metal castings like this so you don't crack the casting or booger up the threads in the casting. Then you really have a problem since replacements for parts like these are very difficult (sometimes impossible) to find.
More later.
/ MM BF restoration-more progress #2
Thanks for the photos of the hydraulic reservoir and control valve. My BF is leaking around where the control lever goes into the reservoir and I need to dissasseble it and replace the O-ring/seal. Now that I've seen your photos, I have the confidence to tackle the project.
Bill
Bill
Glad they were of help to you.
My BF restoration work has been on the back burner for nearly a month. I'm installing a new metal carport and the hay baler needs servicing. Hope to move ahead on the BF in March.
Got back to the MM/BF last week. Took a look at the water pump. It needs a rebuild or replacement--shaft is barely turning. Haven't located a replacement pump yet, only located a rebuild kit from Hercano. Problem is that the pump shaft and bearing are stuck in the cast iron housing. So far no luck in getting the darn thing apart. Tried to press the shaft/bearing out of the housing with my 12-ton shop press. Hard to support the housing securely while pressing. Don't want to crack that housing.
/ MM BF restoration-more progress #5
I would submerge the waterpump in a bucket of ATF/Acetone mix (50/50) for a week and then try to press it out. Next step would use some heat.
I've used ATF/acetone before with mixed results. But it's a good suggestion.
I've ordered some Kroil penetrant. Never used that stuff before--maybe it'll work.
Well, I've been able to make some progress on this project since my last post in thie thread. Been working on the rear axles and brakes.
So I ordered brake lining friction material from McMaster Carr, removed the old linings, grit blasted and solvent cleaned the shoes and bonded new linings on with JB Weld.
I'll be busy the next few weeks mowing and baling hay. Hope to get back to this project in early June when I'll finish spraying primer and start spraying the Prairie Gold final coats.
/ MM BF restoration-more progress #8
Have you made any more progress on restoring your MM/BF? Just curious since I have been following your progress. Enjoy looking at the photos too.
Bill
Bill
Thanks for your interest.
I'm busy with another project now so the BF is on hold.
I need to finish priming all the parts (about 2 days work) and then spray two coats of Prairie Gold (the red parts were painted last year).
I'll get back to the BF in Sep and put on a big push to get that project finished.
Only snag is the water pump--haven't been able to locate a replacement. Looks like I'll have to get the old one rebuilt. The bearing is stuck in the housing right now. I'll see if the guy at the engine rebuild shop can figure out how to press it out without destroying the cast iron housing.
/ MM BF restoration-more progress #10
That hydraulic pump looks similar to mine on my Cockshutt 40. That makes me understand it more and feel I may be able to rebuild it myself.
Great pics !
rriley
It's been a while, but I finally got back to this project after spending the better parts of two months building a Japanese pergola.
The parts have been sprayed with grey primer and now its time for the fun part--spraying the Prairie Gold outer coats.
I'll be spraying PG for another week or so. Then do the brakes and then start reassembly--rear end first.
Progress at last--finished painting the Prairie Gold parts--lotsa big parts and little parts.
Now onto reassembly.
First job--rebuild the U-joints on the propeller shaft (aka drive shaft) between the engine/clutch and the tranny/rear end assembly. The shaft is about 25" long and has rather small size U-joints on each end. The U-joint on the engine end is working OK, but I'll rebuild it anyway. The joint on the tranny end is siezed around one rotation axis so it needs to be rebuilt regardless.
I'm using that U-joint tool from Harbor Freight--works OK.
I pressed out one of the cups. Problem with these small U-joints is that the cup only presses out about 0.2" so it's hard to grip the end of the cup in a vice or with Vice grips to pull the cup out of the yoke. Still scratching my head over this glitch. Want to get the cups removed without possibly messing up the yokes by beating on them with the BFH.
I messed around Saturday with the U-joints. No luck pressing the cups out. I'll get the 4-1/2" angle grinder fired up with a cutoff blade and slice up the spider. The cups should press out then.
Got the U-joints disassembled without cutting the journals (aka cross, spider). Had to use a little bit of hammering to get the job done. Trying to press out the caps with that HF c-clamp style tool didn't work. It pushes one cap out and the other cap into the yoke. Problem was that I couldn't get a grip on the exposed cap to yank it out.
So I set the U-joint assembly in a vise as shown here. Then I carefully hammered on the yoke and drove out the top cap in the photo. Flipped the assembly and repeated for the other cap.
That method pushed the caps out far enough to get to the seal rings which I managed to pry apart with a screwdriver and a long nose pliers. The journal dropped out then with no problem.
This small 1951-style U-joint is pretty rude and crude--no needle bearings, just the caps acting as bushings. The journal is drilled out so you can pack some grease there, but I don't think its a good way to get lubricant to the moving parts.
The auto parts guy was able to find a matching U-joint rebuild kit--should be at his place today.
Next- seal the inside of the 12-gal fuel tank that has lotsa rust and a few holes. I used a piece of copper foil and JB Weld to seal the largest hole (about 1/4" diameter).
Not the best looking patch job, but it's on the bottom of the tank where nobody will see it. I need to clean out the inside better. Plan to dump a couple pounds of steel nuts into the tank and then shake it up. Don't know if my paint shaker can handle the tank. May have to use the old fashioned method--attach the tank to the rear wheel of my Mahindra 5525 and drive around awhile to get the nuts to knock off the rest of the rust. Then I'll seal the tank. Don't know which sealing product I'll end up using. Need to do some homework here.
/ MM BF restoration-more progress #15
Hey Flusher,
Looking real good. As far as your tank goes POR15 has fuel tank repair products/kits. I have not used their fuel tank products but I have used their paint and other body work products and they are excellent. Their stuff is not cheap, but its well worth it when your goal is to do the best repair possible. I've painted three truck frames with their paint, the rockerpanels of my truck, the angle iron and hooks that I welded to the bucket of my tractor and other misc. items. 90% of the paint is still on the tractor bucket even after I've moved about 100 yards of sand and crushed stone! I couldnt believe it held up so well. Wear rubber gloves when using their products or you will be wearing in on your hands for a week! :thumbsup::) Check out their website POR15.com. Their body filler is excellent too, much better than what you would buy at any auto parts store.
Thanks for the info. POR15 is one of the candidates I've checked out. As you say, it's pricy, but probably worth it.
Was able to make a little more progress on reassembly. Got the right rear bull-gear-type axle reinstalled today. It's heavy and bulky.
Cut paper gaskets 1/32" thick to seal the axle-to-differential housing joint. Permatex gasket sealer (the tacky kind).
There's a large banjo fitting that's sandwiched between the axle and differential housings. It carries the right main rail that forms the main part of the forward tractor structure.
A couple of hoists and some chain lengths make the job fairly easy.
But it still took me the better part of 2 hours to get the axle fitted into the differential and get the bolts retightened.
/ MM BF restoration-more progress #19
Looking real nice, Flusher! :thumbsup:
I'll admit I had to do a bit of research to see that MM stands for Minneapolis Moline.... Saw my first one of those at a tractor exhibition/rural fair in MO last summer; there were actually a pair of them there. Looked like they were very well made, nice heavy steel used. The two I saw were quite a bit larger than yours, but I don't remember what models they were....
I'll also be waiting for the finished pics!
Curious: did your replacement u-joints come with needles in them?
/ MM BF restoration-more progress #20
Flusher The BF is going to look great.
I have been lurking on this one as My Dad actually owned one in the early 60's, He had a mowing machine and a set of plows for it as well. He sold all of it in 1962 for a whopping $750.00 and it was in great shape ! Good Luck on her, I am extremely envious.
2021 John Deere 5230L Applicator (A63109)
2021 John Deere...
2018 Freightliner M2 106 Single Axle Dump Truck, VIN # 1FVACXFC4JHJM9637 (A61165)
2018 Freightliner...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
(4) ROW FIELD CULTIVATOR (A62130)
(4) ROW FIELD...
UNUSED RAYTREE REDM32 - 32" HYD EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
