TripleR
Super Star Member
- Joined
- Mar 5, 2009
- Messages
- 18,538
- Location
- Missouri
- Tractor
- Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
Sorry about the double response, but just realized that operators without hydrostatic drive may not realize that the tractor slows/stops as you release pressure on the hydrostatic control pedal. On my Kubota the brake pedals are located immediately above the control pedal, but they are rarely needed. If the need should arise to have both forward movement and an expedited turn radius, the control pedal can be used in combination with one of the split pedals to accelerate the turn.
I was a big fan of split brakes until 4WD came along. Now I use it mostly when using the front bucket to smooth gravel while backing-up, or near an edge in slippery terrain conditions. Kind of like doing the hokey-pokey and shaking it all about:laughing:.
JC
When your life flashes before your eyes, make sure you have plenty to watch :thumbsup:
Couldn't you use the "cruise control" instead of the foot operated HST and use your split brakes? I don't bother with split brakes on a 4WD either and just keep them locked together.
When I transitioned from a 2WD to a 4WD, all I managed when using split brakes was to drag a tire, tear up the ground and effect the turning radius only marginally if at all.
I pretty much agree with your first post, being and old codger myself. I don't have much use of my left leg and have had to "multitask" for many, many years.
