Recommendations for pallet forks 400CX loader on a 4120
   / Recommendations for pallet forks 400CX loader on a 4120 #1
tschwerm
Southeastern Wisconsin
John Deere 2005 4120
What I have been reading it seems like fixed adjustment pallet forks are better on a FEL. That being said what brands are recommended?
   / Recommendations for pallet forks 400CX loader on a 4120 #2
Does you FEL have the JD skid steer attachment carrier? If yes, then there are a lot of possibilities. If no, then your kind of limited to JD for the most part.
I vastly prefer the fixed over floating tines.
   / Recommendations for pallet forks 400CX loader on a 4120 #3
I have MDS forks and they are SOLID as a rock.
I have the JD attachment version not the skid steer.
Where do I find the MDS brand are they fixed?
   / Recommendations for pallet forks 400CX loader on a 4120 #6
Beavis
Do you have a view of the MDS forks showing the adjustments possible...or are you saying they are fixed in one fixed position?
   / Recommendations for pallet forks 400CX loader on a 4120 #7
Everything Attachments which is now a vender on here sells the Construction Attachment forks. There are some forks made by Horst that have been given good reviews as well.
   / Recommendations for pallet forks 400CX loader on a 4120 #8
Here is a picture from the back side. There are 11 notches along the rail which allow you to set the pair of forks in 5 different settings, or you could set a single fork "dead center"
   / Recommendations for pallet forks 400CX loader on a 4120 #9
Fixed forks refers to the fact that they are rigidly mounted to the frame. Floating means they will pivot away from the bottom of the frame. Fixed allows down pressure on the tips. Floating is more forgiving when doing pallets on a hard surface.
I have the JD fixed ones. Strong, easy to use, heavy. Same works for 200-500 series FELs.
   / Recommendations for pallet forks 400CX loader on a 4120 #10
How many buckets do you have? It might be worth your time to invest in the Skid Steer carrier and go with the SS Forks/Bucket/etc...
Opens up alot of possibilites, especially in pricing....
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2023 MAXXD TDX Drop-N-Load Trailer with Air Ride Suspension and Tilt Deck (A51039)
2023 MAXXD TDX...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
TRUCKING INFO (A50775)
2020 MACK PINNACLE (INOPERABLE) (A50854)
2020 MACK PINNACLE...
