Planting mini forest on wet field
/ Planting mini forest on wet field #1
Brad d
So my lot is 250'X760' deep and the back is lower than the front and does not have that good of drainage.. because we built up the front when we built the house and so did the guy next door.
now I would like to till it up but the water seems to sit all summer (im up in winnipeg manitoba) some spots are dry but a lot of it has a inch or two of water on top.
What do you think the best way to prep this is? Bulldozer, or would that sink in the soft mud? All I have is a BX1500.. so that is out of the question:D
Or should I just dig a pond and plant the trees around it?
goes to the back of that green hill, about 400' from where this pic was shot
/ Planting mini forest on wet field #2
Brad you will need to be careful about what type of trees you select. Many a tree will not live with wet feet,if you know what I mean. It sure would be better is you could get the area to dry out.
MarkV
/ Planting mini forest on wet field #3
A pond is always nice, but do you have a source of water from ditch or can divert water into the pond to keep it high?
Either build a pond with trees in background or bulldoze area to divert water to your road ditch andd plant trees.Perhaps you could have both water loving trees and a pond at same time ? Some trees like alot of water and can suck up gallons like willows.
/ Planting mini forest on wet field #4
I don't know what grows that far north but I agree with you. Pick the tree varieties that love wet feet and they will help dry the soil. Here that would be willow, cotton wood and sycamore.
/ Planting mini forest on wet field #5
You didn't mention budget. Digging a pond costs money. Digging a ditch to drain the water is less money, but you have to be careful what you do with that water. Will the person who gets it on his land be happy or angry about it? If you go the pond route, digging is easy, spreading the dirt and moving it away from the hole in the ground is the hard part. Since you have standing water well into winter, I'd say that you shouldn't have much of a problem keeping it full.
What do you want to do with the land? Grow crops? Raise animals? Or just have a big lawn?
Eddie
Eddie
Well for budget.. i would spend a few grand.. I would think a guy with a machine would cost 150$ ish a hour.. and what would it take a few days?
Like you guys said getting the water out front is going to be a pain, there is a ditch that runs along the front. And its lower than the field.. but water sits all year round.. and just raises mosquitoes:mad: So i figure no water or a big body of water with some fish would keep them at bay.
Plans are to stop the wind.. have some trees to look at and keep a bit of wild life around (right now we have ducks, Canadian geese on the little amount of water + prairie chickens, snow owl, fox.. ect)
I have looked at that pond boss forum and looks like you need a clay base.. my yard is 1' top soil, 4' of silt then many feet of heavy gray clay.
"added red dots to my property line"
/ Planting mini forest on wet field #7
HI Brad D !From which part of Winnipeg are you? I'm from your part of the world and often see big signs in new areas posting wanting clean fill ! Might be a solution to your problem depending on how low your lot is.
Ron
/ Planting mini forest on wet field #8
And its lower than the field.. but water sits all year round.. and just raises mosquitoes So i figure no water or a big body of water with some fish would keep them at bay.
As long as the water does not move it will raise mosquitoes and as I remember it in Manitoba the mosquitoes eat the fish not vice versa:eek::eek:
I would (and have) plant nanny berry, red osier dogwood and or tamarack to grow fast and attract wildlife -- willow would also work. I would be tempted to start with a small deep pond with channels cut to it to drain the outlying area. As Eddie points out, if you do decide on a pond make sure you plan it so the topsoil is accessible and not buried under the clay:eek:
regards
/ Planting mini forest on wet field #10
If the ditch is lower and you really do not want a pond...I'd say put some drains in. You could likely put some "sock covered" 4 inch lines to a larger 6-8" drain and let gravity do the work. It takes very little slope for water to move...and slow draining 24 hours a day can do a lot. Your tractor will not be crushing any of the lines if they are burried much at all. And this is something you can do in a handful of weekends. Maybe run in the long 6-8" main drain to the ditch one long weekend. Then you can add 4 inch lines as needed. You may find that only one or two of the perforated lines at the lowest areas do all you need. Most trenchers can do the 4 inch line. The 6 might take a small hoe. Either one can be rented for little dollars compared to the work that gets done. Or higher the main line (pros have laser levellers and helpers!). I had a 1' wide by 4' deep line dug for electric for about a $1 foot a just a few months ago (times are hard though and I back filled myself).
I have also heard (no personal knowledge though) that "swamp oaks" are great in wet areas. I am told they are a type of white oak. They still have the deep roots so they do not blow over or break easily like some wet area plants.
Let us know what you plan to do and send some pics as the project develops. Bwest of luck to you.
/ Planting mini forest on wet field #11
Yes, swamp oak, sycamore, and walnut do well with wet feet. The far back side of my property is real low and holds water year round and the trees are huge. But, then again, I'm not familiar with your region. One concern I would have is the wind and would worry about the trees toppling over in time. I deal with that alot and my woods are in a valley sort of protected. You may want to contact the local forestry division and get some recommendations from them. Sometimes they will provide you plant stock to rehabilitate the habitat.
If it were me, I would do some woods, bog, and pond.
/ Planting mini forest on wet field #12
You may want to talk to your county ag office. I have a similar problem with a wet/damp field that i am tired of spending money to mow. I enrolled in the crp conservation reserve program, aka crep. The fed goverment is paying me to plant trees and shrubs on the property, i cannot cut the trees down for 15 years, but i do get a stipen to spray, and cost share on the cost of tree tubes, stakes, and trees. I will be planting next april and will put in approx 100 trees and 50 shrubs. Once i start planting i will post some pics. They also have lists of trees that will work in those areas, even if you dont enroll in the program. But if your going to plant why not have some help with the cost and planning?
Forgeblast
/ Planting mini forest on wet field #13
Some other choices for trees who don't mind wet feet. River (Niger) Birch, Cypress, Larch (Tamareck), Willow if you like them.
well guys right before winter i went for it and got a small pond dug, the snow just melted and the water is still a bit high LOL but in a month or two it should go down some.. i used a little laser level and a pole to see if the ditch water is lower or not.. the ditch is about 275' away and if my cheap way of checking worked he pond is 11" higher then the ditch.. so i might build a little ditch to control the over flow.
now i need to aerate it and put some rocks and weed cloth around the edge so i can cut the grass around it.. and some fish so they eat the bugs:licking:
/ Planting mini forest on wet field #15
Appears it was dry enough to put a crop in near the pond last year.
Now you have the spoils to spread and build up the area around your pond for lawn and trees.
haha most of that crop was bulrush we just mowed it down with a tractor. at the end of the year it just dried out enough to do so.
2009 Ford F-150 Ext. Cab Pickup Truck (A60352)
2009 Ford F-150...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
New/Unused Landhonor 20,000lb Electric Winch (A61166)
New/Unused...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
