Price Check Is this a good deal?
/ Is this a good deal? #1
savart
I have about 1 acre of land with a fairly large ditch. I am looking for a quality tractor that is going to last me for years. After comparing the Cub, Husk, Kubota, and Simplicity. I found what I feel is a great deal on a John Deere X520. The Deere has a liquid cooled engine, 54" deck, aggresive tread rear tires, larger wheels, psoit track, and a repitale dealer. I think this tractor is a bit more than what I need but with the warranty and the deal I have on this tractor I don't think I can pass up the deal.
Thoughts? on the JD X520?
John Deere products for homeowners: Features for X520 Multi-Terrain Tractor
/ Is this a good deal? #2
What kind of a deal ?
/ Is this a good deal? #4
Welcome Savart. Is that $5,300 MSRP? If you haven't already, the JD web site lets you build and price your tractor, thereby giving you MSRP.
I've heard other members say that you should be able to get 15% - 18% off MSRP on a CUT. I don't know if that rule of thumb applies to garden tractors such as the 'X' series.
/ Is this a good deal? #5
That tractor is pretty good. It would serve you well.
But, if you really want one to last you a lifetime, reduce your maintenance burden, and save a little money. Look for a low hour (<1000) JD 455, or 445, or 425. Way better tractor. Comparable to the new x700 series. No, you won't get a warranty. But, it is very unlikely that you'll need it either. These can be had for as little as $3000 (425's).
The older 400 series is all shaft driven (drive and mower), has real hydraulics, can be fitted with awesome attachements including 3pt., are liquid cooled (quieter, longer engine life), Heavy and stable.
For my money, I'd take a used one of these over anything short of an x700 series.
I have a 425 all-wheel steer. Been using it now going on it's 17th season, 900 hours. I spent a grand total of $75 on repairs (ignition module in year 3). Never changed a belt. Mows very fast. Moves snow like a dream too. Add/remove any implement without any tools. Mower on/off in just a couple of minutes. Real easy maintenance. Everything still works like new. Quietest tractor I've ever been around.
/ Is this a good deal? #6
I like the 400 series mentioned above but for one acre and buying new that is a reasonable deal. That is about 20% off I think, probably not going to get more off than that on a riding mower.
I don't know what the blade tip speed is but this is a fast riding mower with a forward top speed of 7.2 mph. If your yard was smooth and open you should be able to cut in about 30 minutes. So you should have limited hours per year and with good maintenance and no abuse it should last for quite a spell.
/ Is this a good deal? #8
I would like to get my hands on a 455 AWS; but
they are hard to find
in Colorado.
I couldn't find one
when i was looking.
so I went with this for $5250 tractor and mower.
After having it a little over 2 years I'm very glad i didn't find a JDx455 as there is no way I'd trade the BX1500 for one.
/ Is this a good deal? #10
Yup... it wouldn't be a real fair trade. 'Course it's not really an apple for an apple comparison, either...
That said, you done well with that purchase - sorta fell in - and came up roses! :D
AKfish
/ Is this a good deal? #11
I looked at the BX 1500 and 1800 and ended up with a 4010. Waiting to see if JD gives us another 18ish hp diesel by around 2014. The JD dealer is the nearest to us, same outfit owns both Kubota and JD dealerships here around Charlottesville (and Orange).
That price on the x520 sounds really good. Think that's a gas engine? They'll use 50% more fuel than a diesel. I really like a diesel for the economy plus quick starts. Also starts on about the first 1/2 turn of the crankshaft (after a 2 to 4 second glow, of course).
Ralph
2023 Kubota SVL97-2 Compact Track Loader (A63118)
2023 Kubota...
KUBOTA M135X TRACTOR (A62130)
KUBOTA M135X...
2024 John Deere 4066R Tractor (A63116)
2024 John Deere...
Sterling 9500 (A63118)
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
UNUSED SDLANCH 20' X 30' ALL-STEEL CARPORT (A62131)
UNUSED SDLANCH 20'...
