Tractor maintenance for newbies?
/ Tractor maintenance for newbies? #1
2dawoodz
I am helping out a friend who use to have someone service his Ford NH 1920 tractor. Besides oil/filter and greasing zerks, what other maintenance items are there? I know I can measure the amount that drains out but is there a website I can check to find out how much oil this thing holds? No owners manual. Thought I would replace with a 15w40. Same question for the oil filter. Would the local Advance Auto store have a listing for tractors?
Thanks in advance for your feedback.
/ Tractor maintenance for newbies? #4
2dawoodz,
Check out this link below to Messick's ..I think it will have all the information you need for all you want to do..just click on the items on the left of the page and it will load...here is the link >
New Holland 1920 4 Cyl Compact Tractor 20 Series (1/87-4/02) Parts Catalogs
/ Tractor maintenance for newbies? #5
No dipstick?
Just be sure the oil you buy is rated for diesel use.
/ Tractor maintenance for newbies? #6
While you can xref the oil filter number at napa.. I urge you to just get the oem oil filter. it's only a lil more than the napa one anyway.. and the napa one crosses to a car filter anyway.
you want a hyds and air filter too, plus a C rated 15w40 oil.
you will want utf fluid that meets the M2C134D spec.. walmart and tsc carry this ( same with the motor oil ).. the ambra G utf at the dealer is fine.. but expensive.
check the pow steer fluid.. takes utf as well.
sump in the trans/diffy/hyds has a dipstick near your right toe in the op platform. If it has 4wd, front axle takes the same fluids.. there are drains and fills and a stick on the front axle.,..... Yer manual that came with the tractor lists this info.
I used to have a 1920.. and my OEM manual had all this great info in it.
grease the zerks, adjust the clutch when needed, fix stuff that breaks.. keep the tires inflated properly.. check blets and hoses for fraying, cracks and leaks.. use good coolant, preferably CCA treated like most fleet diesel mixes.
if it has 4wd.. use it now and then to keep it engaging smooth and roll the gears over up front now and then.
keep trash and leaves cleaned out of the minscule lil toolbox behind the seat so it doesn't collect moisture and rust out.
lube the pto stuf and keep the plastic cap over it when not in use.
clean the screen at the radiator or at least check it often in dusty or conditions that make chaff... like mowing.
IMHO.. the 1920 and the 2120 were some of ford/nh's best offering in that size range.
soundguy
Thanks everyone!
Wow, Thanks Soundguy. A couple more questions:
Are you saying there is a filter for the hydraulics? If so where is it located. Where is the fuel filter located? Should it be clean or replaced?
Is "utf" trans fliud?
What is the recommended tire pressure?
How often should coolant be replaced
soundguy
/ Tractor maintenance for newbies? #9
How many hours: manual will specify periodic changes including draining hyd. system and changing filter, front axles fluid change, power steering fluid change. Make sure pivot fittings on front axle well lubed-if you have a loader take pressure off front end to better distribute grease.
The owner can not remember the last time maintenance was performed and what specifically was done so I am suggesting all fluids need to be replaced.
Are pivot fittings zerks?
/ Tractor maintenance for newbies? #11
yes there is a hyd filter.. as memory serves me it is under the right running board. fuel filter should be replaced.. just follow the line from the tank.. somewhere befor ethe injector pump will be a filter housing. OR check yer parts manual.. it will show you.
UTF stands for universal tractor fluid.. some call it transdraulic fluid. it is a multi-purpose fluid for use in your tractors tranny, diffy, final drives, front axle, power steering and hyds... pretty much goes in every hole but the crankcase.
check the manufacturers specs onthe coolant.. the bottle will tell you how long it is good for.
tire pressure.. well, the tire likely gives you the max pressure allowed, and the manual may specify a pressure.. but most of us inflate the tire till sidewall deflection looks good and the tire is not squatted under normal load, though not exceeding burst pressur eonthe tire.. etc.
soundguy
/ Tractor maintenance for newbies? #12
most of the pivots HAVE zerks.. IE.. front axle pivot, and pedal pivots.. etc.
soundguy
INOP/NON-RUNNING 1990 Peterbilt 378 Tandem Axle Day Cab Truck, VIN # 1XPFDE9XXLD293381 (A61165)
INOP/NON-RUNNING...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
UNUSED JCT DUSTLESS BLASTER (A62131)
UNUSED JCT...
2018 Towmaster TC-16 10 Ton Tag A Long Trailer (A61568)
2018 Towmaster...
