3 point lowering speed knob question
/ 3 point lowering speed knob question #2
DOn't know what to tell you. Mine wouldn't budge either when I first got the tractor (it was used). Since everything was working fine and I didn't feel like putting some pliers on it. Then weekend before last I was mowing and noticed it was loose. WTH?? Almost felt like it was going to unscrew and come out or something so I gave it a few turns...not thinking. I was running the FM and needed to lift it over some junk and it stuck up. Long story short I had twisted the knob an hour earlier and forgot. After a couple jumps on the FM and linkage checking, I remembered the knob. I'm gonna leave it alone from now on!!
It should move though.
Good Luck,
Rob
/ 3 point lowering speed knob question #3
Mine was stuck so solid when I got my L3400 that I wasn't sure it was supposed to move.
After determining that it was, I soaked the shaft with WD-40 for about 24 hours. Of course, it still didn't budge but after puting alternating CCW and CC pressure with hand power for 15 or 20 tries and more WD-40, I sensed that it budged, probably 1/128th of an inch. Back and forth 30 more times and more WD-40, now I can turn it with my pinky.
Persistence may be a good alternative to force for this one. LOL
It worked fine when i got the used BX1500 in november but it's stuck now.
/ 3 point lowering speed knob question #5
Try the one on the new BX1500 or the BX23. LOL
Sorry Lee, couldn't help myself.
Now you got me worried, I haven't played, er I mean tested mine yet. I'll let you know tomorrow.
/ 3 point lowering speed knob question #6
it may seem obvious, but it really is hard to move when the weight of the mower deck is on it. make sure you raise the 3-pt hitch and deck if attached up so it frees up the linkage on the knob. if that doesn't do it, take a look under the machine and make sure there aren't any sticks or other gunk jammed in the threads or the little stepped cog that the mounting arms settle into.
amp
/ 3 point lowering speed knob question #7
Ditto "ampsucker's" post. I have found on my bx1500 that the knob is very hard to turn with the mower lowered. But raise it up and turns rather easily.
/ 3 point lowering speed knob question #10
I think you're confusing the mower deck height adjust (left side of machine) with the lowering speed control (right side of the machine).
Sprayed it yesterday with wd40 several times .
Was still stuck this morning.
Sprayed it with PB Rust Buster.
Taped it with a hammer a few times.
Clamped a small pair of vise grips on the shaft not the plastic knob.
Gave a fairly firm tug on the vice grips and it broke free.
Lubed it up good with white grease amd it turns free and easy now.
Think I will clean it and lube it at each engine oil change.
/ 3 point lowering speed knob question #12
Glad to hear you got everything working the way its suppose to.
I do not have a BX, but I do have a B7610 with the same 3 pt lowering speed adjustment knob. I think your idea to check it and at least lube it a little on a regular basis is a good one.
Dascro said:
*Glad to hear you got everything working the way its suppose to.
*Thanks.
I'm going to do the same with the mower height setting knob too.
I've had them freeze up on me also.
/ 3 point lowering speed knob question #14
yep, i WAS thinking of the mower height knob. sorry bout that! sounds like they both suffer from a similar problem, though.....
* sounds like they both suffer from a similar problem, though.....
*I've had problems with both knobs but not on the same tractor.
/ 3 point lowering speed knob question #16
So I was working on my BX2230 today trying to get to the hydraulic system fan, and unscrewed the 3 point lowering speed knob... fluid came out :( I quickly realized that was a mistake! I screwed it back in immediately but I am worried it is broken now. What can I do to fix it?
/ 3 point lowering speed knob question #17
I suspect its fine. It sounds like you lost the retainer ring stop of some sort. On mine the valve goes only so far. Have you tested to see if if still lowers and control the speed of lowering the 3 pt arms ?
/ 3 point lowering speed knob question #18
I'm a little late to this thread, but what the heck....
I new at all this stuff and digging for knowledge. THIS subject is actually something I can address with "expertise".
My new to me B20 came with a lowering adjuster that was non turning.
I tried my maximum manual twist, which though not as vicious as it used to be, is still pretty reasonable. No joy.
Knowing from reading the manual that it was supposed to turn, and the knob being metal, not plastic, I first put some penetrating oil on it. After a while I searched out my rounded jaw channel-locks grabbed the knob and .... nothing but scraped up knob and a bit of twisting of the rod. Scary stuff brute twisting a strange knob.
To help eliminate scarring up the knob some more, I tightened up the pliers
and took a stronger grip. I cranked in both directions, being mindful of not
making the shaft torque much. Ever so slowly I got it to tighten a smidge.
I then worked it back and forth, and little by little the shaft freed up!
The system now works as advertised.
The moral of the story seems to be that one should keep this thing lubed up and exercised on a regular basis, perhaps while doing the "10 hour" joint greasing routine.
And, perhaps this is a system that is underutilized because of misunderstanding or lack of knowledge as to it's benefits.
OK old hands, what's the poop on best practices with the 3-point lowering speed adjustments.
Regards,
Dennis
/ 3 point lowering speed knob question #19
Once you`ve got it moving, smear some grease around the shaft where it goes into the casing. And stop washing the tractor, water gets around the shaft and rusts it solid.
My 2 cents
/ 3 point lowering speed knob question #20
My 2 cents
Or leave it sitting in the rain etc. One thing nice about the ROPS is that it makes a good tent support if you bungee a good sized tarp over your rust prone iron if leaving it out.
Dennis
