Grading ck30hst r4, rear blade size
   / ck30hst r4, rear blade size #1
CurtC
Indian River, MI
Shopping, Kioti CK30, Farmall 450D previously
I'm looking to get a rear blade for snow plowing. I'm using a 5' box blade now, but I want to be able to angle.
I'm looking at 6 and 7 foot blades, and I want to be able to rotate the blade around without detaching it. If you have a 6 or 7 and can flip it around, I'd appreciate hearing what brand/model it is, thanks!
   / ck30hst r4, rear blade size #2
Curt,
I've got a 6' on mine and I don't have any problems spinning it around.
It's worked great (almost) for the five years I've had it.
With the past two snowstorms here (30" & 20") I found it a little difficult to get up my concrete driveway at times.
I believe when I get a set of chains, that problem will go away.
I'm sure the 30 would handle a 7' Blade, just not sure it would spin around.
Tom
   / ck30hst r4, rear blade size #3
I have a CK25 with a 7' blade (heavy duty), I can't spin it around. I use it angled and it works great.
Harvey
   / ck30hst r4, rear blade size #4
Yes. 7 footer will spin around. but, just barely.
   / ck30hst r4, rear blade size #5
I have a 6 footer and it works great but I would prefer a 7' - like you say, as long as it spins.
   / ck30hst r4, rear blade size #7
I have a 7' blade on my 30, I can spin it around but top link and 3pt heights need to be 'just right' for it to go. I believe the brand is a Sundown, I am out of town and won't be home until Thursday... I can check then if you want.
   / ck30hst r4, rear blade size #9
Landpride model 2584 (7 footer). Spins around without any problems and is very heavy. I use it for snows up to around 8 inches. After that it's time to fire up the old WM300.
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
UNUSED PABREAK GB232 - 84" HYD GRAPPLE BUCKET (A57193)
UNUSED PABREAK...
2014 Nissan Altima Sedan (A55853)
2014 Nissan Altima...
CASE TV370B SKID STEER (A52707)
CASE TV370B SKID...
7033 (A51691)
7033 (A51691)
