Lifting capacity,hydralic pressure BX24
/ Lifting capacity,hydralic pressure BX24 #1
samofsweden
Gold Member
Kubota Bx24, 2007
Hi. Had a look at BX Panded website, nice one! Found a interesting thing, a hydralic pressure meter "get the most out of your BX". Has anyone change the factory setup (hyd pressure) ? Kubota has some kind of safety zone. I would really like to be able to lift more.
It feels that Kubota arent up to lifting.... for exampel the M59, it only lifts 1350kg! (and that is with bucket, with pallet forks I guessing only around 1000kg!!!)On a construction site here in Sweden 1500kg is a minimum, thats a pallet of groundstones. Anyway back to pressure changing...
/Sam
/ Lifting capacity,hydralic pressure BX24 #2
actually- I found that most of the BX's seems to be under "factory specs" I had to bump up mine to be at the factory specs and boy it feels like a whole new machine. I thought about going over a little but decided not to since bumping it up was enough for me.
/ Lifting capacity,hydralic pressure BX24 #3
If one could get a BX to lift 1500 kg it would be on it's nose:laughing:
Skyco you are correct, I was refering to Kubota M59 ;) I would really love my BX to lift 500kg, but I will need to buy an B3030 or B3200 for that:licking:
Thanks Radioman, I will check the pressure soon.
/Sam
