Garden Tractor Fluid Leak - Help?
/ Garden Tractor Fluid Leak - Help? #1
savaytse66
Pennsylvania
2010 BX25
I have a G2160 garden tractor that I use mostly to mow and occasionally plow snow. For most of its life, I've kept it in the garage, but over this winter, I've needed to keep it outside with a tarp over it. Today I went out to plow, and I noticed a spot in the snow that I thought might be a gift from one of the neighborhood cats. But once I started it up and made a few passes up and down the driveway, I noticed that I was leaving a trail. So I parked it and turned it off to take a look, and noticed a nice, slow, steady flow of fluid dripping from above the left rear "driver's side" tire.
The fluid looked like new engine oil; a relatively translucent goldish-brown liquid with some viscosity to it. Since I haven't changed the engine oil since last spring, I'm pretty sure it's not that since I would expect it to be much darker. The lever that moves the snow blade and MMM up and down is above the general area as the leak, so I'm thinking it could be hydraulic fluid? But I'm rather ignorant when it comes to mechanical stuff like this, so I'm looking for some guesses.
Since the tractor is outside, and I have no room in the garage to examine it right now, I wasn't really able to get a good look. But I'm thinking it's probably a bad hose. Does this sound like a good possibility? If it's hydraulic fluid and hose, how big of a deal is it to fix? Is there any danger operating the tractor with a leak like this, or would it just render the hydraulics inoperable? If I can drive it down to the dealer for service, I'd like to do so, but if it's potentially harmful, I can just have them pick it up.
Thanks!
/ Garden Tractor Fluid Leak - Help? #2
If your tractor is hydrostatic you could damage the tranny. I would either pullit in and find the leak or parkit until then.Alsocheck your hydraulic fluid levels. Make sure its not low
Yep, it's hydrostatic. I'll have to check levels tomorrow.
/ Garden Tractor Fluid Leak - Help? #5
With fluid gushing out in a stream, you're gonna have to top it off with fluid and THEN check for leaks. I know that's wasteful, but necessary. Don't drive it with a leak that bad.
You have leak somewhere. Line? Fitting? Lets hope so. Crack in the housing or similar? Ouch!!!!:eek::eek::eek:
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
2014 RAM VAV 2000 TRAILER MOUNTED VACUUM MACHINE (A59823)
2014 RAM VAV 2000...
