Why so many air couplers? Which is better?
/ Why so many air couplers? Which is better? #1
Denwa
Blaine WA
Kubota B20
Just ran into one of those situations where I *THOUGH* I knew enough.
I borrowed an impact wrench and the couplers would not. I did a bit of looking at options on air coupler fittings and found at least 7 different references.
There's Milton types G,L,M,P and V, and another site listed just Automotive or Industrial. Dang.... Should be simpler, no?
So, other than making sure the male and female coupler are the same desikgn,
what prey tell are the pro's or con's of any of the offerings.
Thanks,
Dennis
/ Why so many air couplers? Which is better? #2
Welcome to my world. Why is one year chevy motor uses filter A and the next year they use filter B? Its crazy.
Chris
/ Why so many air couplers? Which is better? #4
Hey Denwa
I didn't see your restoration project on the 110 til i looked again. I have a 112 Hydro Lift I'd like to get rid of. I started to restore and used for a couple of years but had back trouble and quit using it. Intersted? I have pictures if intersted
Checkout these pages and the ZIP Below McMaster-Carr [click the first pic] & Coupling Shape Benefit Comparison Chart.
Mr Blue1,
Great links, thanks. Guess this shows that it's all kind of arbitrary, with the manufacturers making a bunch of differing connectors just for the marketing fun of it. However, the most common "standard" fitting seems to "industrial",
good for air or water. If one ends up borrowing a tool with a misfitting connector it's easy enough to switch out the fittings temporarily.
Over and out,
Dennis from WA
Hey Denwa
I googled the 112 and saw one on offer on Craig's list from M'Burg WV. That yours? I'd say it's a bit far for the shipping thing and all, but thanks for asking ;' >
One restoration project at a time's plenty for me, and I've got several already.
Dennis
/ Why so many air couplers? Which is better? #7
Yep, when I was repairing mechanics' air tools, it wasn't unusual for me to do that. And sometimes so of the couplers look much alike but won't work.
/ Why so many air couplers? Which is better? #8
Just go buy a cheap matching set at HF and they should at least work with the pieces you get in the set.
/ Why so many air couplers? Which is better? #9
Dennis
Yea that's it. No prob but it never hurts to ask. Got some pics of the 110 you can post
/ Why so many air couplers? Which is better? #10
I've found that the cheap HF ones work with other cheap HF ones. If I use nicer couplers from the hardware store with the cheap HF ones I get leaks. Nice to nice works fine.
I keep the cheap HF couplers around so that I'm not too put out when the hose end gets dinged up from a drop on the concrete. With an assortment of HF cheapies around I just throw the old one out and thread a new one on.
/ Why so many air couplers? Which is better? #14
Milton and others make a universal coupler that will do A, M and ... (i cant remember) Personaly i dont use Miltons, I use Battlefields http://www.battlefield.biz/04series.shtml
They fit :1/4” industrial, the ARO 210, the Euro-high flow, 1/4” Lincoln long nose, 1/4” Automotive Trueflate, and 1/4” Italian plugs. This series was designed to provide maximum flow, interchangeability,
I dont like the cheap plugs. They wreck the good couplers.
If your starting from scratch the V or Euro couplers are better (high flow)
M or industrial are the most common.
Some of the common styles (ie not the "V"s) flow more than others. IIRC Aro's (type A) flow the most in the common styles. (could be wrong, maybe its tru flate "T" style) I had seen a chart once, ill try to find it.
/ Why so many air couplers? Which is better? #15
Thanks,
Dennis
Welcome Denwa, and if you think air couplers are confusing, just wait until you get into the joys of hydraulic fittings. :D
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
Detroit Diesel Auxiliary Hydraulic Power Plant Generator (A61568)
Detroit Diesel...
2009 John Deere Z925A Zero Turn (A63116)
2009 John Deere...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
