The 3 ton unit I have on a horizontal ground loop (and it's a 3 ton loop) has the following dimensions:
The ground loop is two trenches 250' long. They are in theory 5' deep so that you don't need a trench collapse device to be in there. In practice, they may have ended up a little deeper
. An excavator dug the trench and the trench width is 3 feet wide (so it's easy to work in). In each trench, on each side, there is a 3/4" pipe that runs along the bottom, turns at the end of the trench, and then comes back about 2' above the bottom. It is held in with large "staples on steroids" devices hammered into the clay ground.
So there are 4 500' loops, one on each side of two trenches. Note that the 500' pieces of pipe are pre-cut, and they do not get cut again. The total loop lenght is therefore 2000'.
The feed from the house, which is about 100' long, is a 1.25" pipe (all these pipes are black HDPE). It feeds into a buried manifold that connects to each of the loops. Since the loops are the same length and same topology, the flow divides between them evenly.
Everything gets covered up, and then it takes a year for the trench to settle. A pile of dirt is left over and gets used to cover it. Eventually, it's a bit of a depression that I'll have to smooth over to get everything flat again (this is a seat time thing not a problem thing).
BTW, the 8 ton loop is 4 trenches, 300' long for 4800 feet of pipe in the ground.
There is methanol added to the water in the loop to make sure it doesn't freeze and to help keep crud from growing in it.
So, wedge40, I don't see a big limit on how far it is from the house and if it was "too far" you'd just go up a pipe size on the main feeder pipe. You could dig your own trenches, that's a time and money thing. For me, my poor little
B21 backhoe and I would be at it for over a month, the bucket is too narrow, and I'd probably have to dig twice the trenches, and it would be hard to work in. Hiring the excavator was a big win.
All the Geo guys I talked too were not keen on having the homeowner dig and create the horizontal field loops. I think it's an ownership thing. If anything goes wrong, there are two people to point fingers at not one. Yeah, this is more money for the HVAC guy but this was a consistent theme.
I've heard of other schemes, this is just what happened here.
Pete
