Front-End Loader FEL Mounted Plow
/ FEL Mounted Plow #1
kubotainct
2005 Kubota L3130 HST w/ Loader
Hi,
Does anybody know of manufactures that make FEL Mounted Plows?
/ FEL Mounted Plow #2
I have a 72" one here that is a snow/dirt blade. There are 2 bolts that you take out and the spring trip will work for snow pushing or you leave them in and now you have a dozer blade. It is a manual angle or you can add the hydraulic cylinder kit down the road, $1,900 manual $2,300 power angle.
It was a Branson made by America-quip.
There are tons of them out there.
WR Long just started making them.
HLA
Meyer
Curtis
SnoWay
Snow Wolf
/ FEL Mounted Plow
How hard is the manual one to angle?
/ FEL Mounted Plow #4
It is easy enough to rig up...this is a 72" UTV plow mounted to a custom mount in the bucket.
/ FEL Mounted Plow #6
I purchased a 7' Curtis and have been very happy with it.
I highly recommend hydraulic angle.
/ FEL Mounted Plow #7
Hello kubotainct
Welcome to TBN:)
This company also makes them.
As for manual angle,yes it's alot cheaper,but oh is it a pain in the you know what:D
HORST WELDING
Greg
/ FEL Mounted Plow #8
I also have the Curtis set-up 6 1/2 foot with hydraulic angle. Very satisfied.
/ FEL Mounted Plow #9
Meyer is now making them also.
Chris
/ FEL Mounted Plow #10
/ FEL Mounted Plow #13
I got a JD 366 Front blade with the extension kit, 82" width, with hydraulic angle. - very good.
/ FEL Mounted Plow
Does my kubota have to have the 3rd Function Valve to operate the hydrualic angle one????????:confused:
/ FEL Mounted Plow #15
You have three basic options for hydrauilc angle:
1-A true 3rd Function solenoid valve
2-A Diverter valve (splits the dump/curl circuit to direct flow to the angle cylinders)
3-A rear remote valve with hoses running all the way up to the plow.
/ FEL Mounted Plow #16
Another option is a snow/dirt blade from Paynes Forks. I had one and it worked great. It clamped on to the FEL bucket. I have since switched to a Curtis 6 1/2 power angle plow because of trip springs.
My friend who I sold the blade to loves it.
Toro Workman (A62183)
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59910)
2018 VOLVO VNL...
PALLET OF FORKLIFT SOLID TIRES (A63745)
PALLET OF FORKLIFT...
2016 JLG T350 (A62180)
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
