What are hours worth?
/ What are hours worth? #1
Zebra5
When looking at used and comparably optioned/model tractors, how much difference would you pay for lower hours? Say 1000 hours vs 3500 hours?
Is there any rule of thumb for this? $1/hour? $3/hr?
Also what is normal hours before a major overhaul is needed? I am guessing 7000-10,000.
/ What are hours worth? #2
What sized tractor are you looking for?
3000 hours on a CUT (with their 1 to 2 liter (60-120 cubic inch) engines might be ready for an overhaul. Those same hours on a full sized utility tractor might only be 20-40 percent of it's usable life (before an overhaul is required).
Lower hours would be better, of course, but a "rule of thumb" would be pretty much guess work. Even lower hours with a machine that hasn't been maintained might not be as good as a higher hour machine with proper maintenance.
So...you need to be more specific with what you're looking for.
/ What are hours worth? #3
Roy's point is well-made... you need to be more specific regarding tractor size and type.
However, based on your thread concerning engine design in the 5000 series tractor's; I'll take that as what you're looking at --
So, your 7-10K hours is a reasonable guesstimate for that class of tractor's - IMO - given reasonable care and upkeep.
When I'm evaluating a reasonable offer or pricing comparable machines; I break the hours down by a rough scale of "useful working life"; i.e. how much more time could you expect to use the tractor before replacement or repair.
So, an 8,000 hour "class" machine with only 2,000 hours and another similar machine with 4,000 hours would be worth, roughly 25% less; based on the hour meter. That said, there's a whole spectrum of other criteria that are important and can be more important than just the hours on the Hobb's...
AKfish
/ What are hours worth? #4
Roy is right....But I think it TOTALLY Depends on where/who the machine is from. I wouldnt make a blanket statement saying that 3k hours = an overhaul...
I got 3600 hours on the 3TN72 in my F935 and she starts & run just like a new one. BUT, it came off a golf course which took good mechanical care of its equipment. Oil changes came at set points, etc....
The way I see it is a "professional" or "for profit" outfit realizes that maintenance is not an expense as much as it is a key to profitability... Average homeowner John Doe might say "oh I only put a few hours on my tractor this year..no need for an oil change" etc... OR may be the type to buy the cheapest oil on the shelf because its "all the same"...
I've seen my share of machines which while they looked good, were far from mechanically sound...at the other end, I've seen some machines that looked like they were left for dead in the desert...but were mechanically in great condition.
I see "pre owned" machines in 2 scales...
-Beat Up...Beat up means be prepared for a project...and equates to cheap initial purchase price with alot of heartburn & work down the road. If uptime is critical, this is not for you.
-Used...Used machines look great, are in great shape, and typically sell for so much money, with incentives, financing and other considerations such as desireable options, its usually cheaper to go buy a new machine.
In my travels, I've seen very few machines which fall outside of those 2 categories in realistic terms. What I DO see all the time is people with beat up machines asking used machine price...
All of the above is really dependent on location...the tractor market both used & new is fairly strong here in New England...
I am after a 5x20 or 5x25 series tractor. The reason I am not looking at 5X10 series is you can not get a mid SCV, rear couplers are moved to the mid position and you are then limited to one rear SCV. Plus you can't add a 3 function Mid valve.
My must have list is:
Reverser (I want the wet clutch)
FWD, R1 tires
Mid SCVs (for a loader)
Telescoping lower 3 pt links
Open Station
Nice to have, but not a Must:
Isolated open station
3rd mid SCV
Wheel weights
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2011 GORILLA BUILT MANIFOLD TRAILER (A67714)
2011 GORILLA BUILT...
Ingersoll Rand RT-708J (A64912)
Ingersoll Rand...
213121 (A64276)
213121 (A64276)
TOYOTA 5K FORK LIFT (A67714)
TOYOTA 5K FORK...
2012 TREMCAR CRUDE OIL TRAILER (A67714)
2012 TREMCAR CRUDE...
