how to remove broken axle end
/ how to remove broken axle end #22
That ids great I was concerned the gear would drop and not allow you to get the new axle popped in but hey it was like a lot of my worries they never come about.:D
Where did you get heavy duty axles at?
Back in December I bought a Kwikway backhoe that I never got around to installing due to all the snow. I guess they had some deal with Cub Cadet as it came with HD axles for my tractor. The CC service manual has a chapter assigned to replacing the axles if the tractor is to be fitted with a backhoe. They're the same diameter but they must be beefier somehow.
Isn't that the truth. Maybe we sweat the details a little too much sometimes. Thanks much for your help.
/ how to remove broken axle end #25
Different steel.... chromoly 4130 or something.
Fascinating that there are different axle shafts as part of the design process. Really speaks to what they went through to lower the price point.
I think this only applied to some of the first models. Seems like I saw somewhere that it applied to certain serial numbers. Mine is an early 2004. Its interesting that Cub never came thru with a backhoe for this model. When it was first introduced a backhoe was listed as one of the future attachments. Maybe they realized that the axles weren't up to the task. They also started having a lot of tranny problems.
30 Yard Dumper (A61166)
30 Yard Dumper...
2018 RoGator 1100C (A63118)
2018 RoGator 1100C...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2018 Freightliner Cascadia 126 Sleeper Truck, VIN # 3AKJHHDRXJSJW6608 (A61165)
2018 Freightliner...
CASE IH 215 PUMA TRACTOR (A62130)
CASE IH 215 PUMA...
159116 (A60430)
159116 (A60430)
