Ford 770B front loader
/ Ford 770B front loader #1
dboacres
Central Calif hills & Glide, Or
Ford 2110, 1920, 1710
I just bought a Ford 1710 with 770B front loader. Came with 2 L shaped bars with 1" pins for removing front loader. Not sure how to remove loader according "to the book" because I don't have a book. My 1920 w/7108 is very simple to do. Amy one know where to grt an oprators manual? Thanks.
/ Ford 770B front loader #2
I have a 770 FEL manual. It has assembly instructions but not removal procedure. I have not worked a good way to remove the loader so have left it on. If you have trouble finding a manual send me a PM and i can send you a copy or scan.
/ Ford 770B front loader #3
Choose Items
Sounds like the other guy has an assembly manual, not an operator's manual.
/ Ford 770B front loader #4
I can only go by the manual title
/ Ford 770B front loader #6
The assembly instructions assume no assembly has been done to the loader
/ Ford 770B front loader #8
I just purchased a 1710 with 770b loader. Did you figure out how to remove? I would also like to know
/ Ford 770B front loader #9
It is a real simple procedure.
Park your tractor on level ground.
Put the scoop on the ground and hydraulics into float position.
Remove the two large pins at the base of the rear loader arms
Operate the vertical control on your loader in the downward direction to raise the rear loader arms our of the mounting location.
Place the pin of the L arm in the loader mount hole on each side.
Operate control to lower the arms until the weight is on the arms (place a block under the end of the arm if outside so they do not sink)
Move hydraulics until everything is in float position.
Shut tractor off and disconnect hydraulics.
Pull the retaining pins out of the front loader mounts near the front of the tractor.
Wiggle loader manually until pins are free to slide down.
Restart tractor and slowly back the tractor out of the loader.
To reconnnect - drive tractor into position
Reconnect hydraulics
Use hydraulics to lift rear arms and remove L arms (stands)
Lower rear arms and connect large main pins.
Latch front pins and you are ready to go.
2016 KENWORTH T680 6X4 T/A DAY CAB TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
HD 24ft Free Standing Corral Panel with Feed Bunk (A65583)
HD 24ft Free...
John Deere S350 (A60462)
John Deere S350...
